'16 Maxima Headlights
#41
Has go be a better way with getting led lights. I used Silverstar ultras for now but don't expect them to last long. A shop I used for 10 cars to install autostart said for 350 they can convert to leds or hids my choice but I'm worried about the 3 hour install time they said and what they can screw up on my leased car
#45
I previously posted this in the LED Headlight thread. Not 100% sure but believe our headlights are 35Watts. Anyway...
For anyone interested I bought and installed the OPT7 H11s. They were OK but as pointed out in some of the reviews the down road throw is a little weak. So I ordered these from The Retrofit Source (TRS)
https://www.theretrofitsource.com/le...o-2stroke.html. Significant improvement in overall brightness and more importantly down road throw is much improved. OPT7s and Morimoto 2Stroke are the same price $100. For the money the Morimoto 2Stroke are much better and worth trying if your looking to go LED. Can't compare to HID or the OEM LEDs on the Platium as I haven't seen either but more than satisfactory as far as I'm concerned. The warranty on the Morimoto site is 18 months. TRS warranty is 3 years. We will see if they hold up.
#46
#47
Stock halogen headlights
SNGL 5k 55w LED headlights + DD 5k XML2 fogs
#48
Interesting. The OPT7s are rated at 3500LM per bulb. The Morimoto 2Strokes are rated at 5000LM per bulb. The SNGL are rated at 5200LM per bulb. I find the 2Strokes fine for downroad throw especially compared to the OPT7s.
#49
I have these in 5k 55w. In my opinion they are only acceptable with the additional 5,680 lumens from 4 DD fog lights. The beam is much weaker at distance and the throw is not as far as the halogen. But the color is great. They're definitely not as bright as the platinum LED's since we have one as well. The reason I went with these over the Morimoto is that they match the DRL perfectly. Interested to see how the 2stroke compares, even though they are 6k. Still waiting on DD to release their SL1 led headlights and we'll see if they're any good or the same knock off junk.
i am hoping now that it is better than the ebay junk i have on the car.
quality does come with price... most of the time.
#50
I also got some led lights for my fog lights, I got them from www.vanquishauto.com They have a really cool stuff! Their leds are super bright and at night there is a huge difference!
Here is the link for all the lights they have for this car: http://vanquishauto.com/catalogsearch/result/?q=maxima
I will recommend vanquishauto.com to anyone is looking for brighter lights and good quality.
#51
My LED fog lights and HIDS I got from www.Vanquishauto.com
#52
Vanquishauto LED Reverse Lights
This will be my next purchase. I am planning to get them with their other lights for the license plate as well. Love them! What do you guys think? I really love the brightness of the led license plate lighst as well.
#53
Nice!! You've done almost exactly what I described in my post from a few weeks ago. (see link.)
https://maxima.org/forums/8th-genera...ml#post9115705
Few questions: 1) How long did it take? 2) Did you ship them? 3) Is the Black chrome-delete painted or PlastiDip? 4) Please describe the Halo you used as that is what I want do as well. (see image below) 5) Cost? (In the research I’ve gathered it could cost between $900-$1,200)
#54
tia,
Ian B
#55
How to remove headlight assembly
Hi Guys,
Since this is the thread on the LED and HID discussion on the 8th Gen, I have the 2017 Platinum and I am wondering how to exactly get to the high beams easily? Do I need to remove the assembly on each side to get access to it? If anyone has the steps on doing this I would very much appreciate it. Also do you need to drop the splash shield on the bottom to access the fogs like with previous models?
#60
You do not need the resistors however see my post above. I ran the OPT 7 for a few weeks but didn't like the lack of down road throw. For a few dollars more you can get the Mirimotos 2Stokes. Better light in my opinion.
#61
2016 Maxima
Hey guys! Just got me a 2016 Maxima. I'm interested in changing the stock halogen lights to LED. Can you guys provide me with a few links to some good realible LED that are plug & play and not too complicated to install. Thanks!!
#62
If you have a platinum, i wouldn't even think of changing low beams to anything. IF you are unhappy with the color i would go with TRS only if they provide anything for a Maxima. For SR i don't know as i don't know anything about it for low beams, i own 17 platinum so i know it has leds for low beam.
The reason why i say don't change is because previously i owned a 2013 Altima, and before i got TRS HID kit, i installed all the ebay leds, hids and there was always something going on e.g, lights would give, wouldn't start, flicker when really cold. If left on automatic and start car they wouldn't start, ballast would give and it was a pain to change them. What i mean to say is that to get into changing a bulb or an entire hid kit is a pain, to getting under the car, turning wheel, opening the plastic etc etc. I suggest, leave them as OEM. After i installed TRS kit on Altima i didn't have any issue.
The more you change your vehicle, the more work it might need. To my platinum, i only switched out easy LED bulbs.
good luck with your HIDS!
#63
Vanquishauto LED Replacement Lights
I have ordered my led lights for my vehicle from vanquishauto.com
I ordered all leds and all is white color so it match with my led headlights.
here are the links for the parts I ordered.
https://vanquishauto.com/2016-nissan...h-beam-h9.html
https://vanquishauto.com/2016-nissan...front-h16.html
https://vanquishauto.com/2016-nissan...-beam-h11.html
https://vanquishauto.com/2016-nissan...-bulb-921.html
https://vanquishauto.com/2016-nissan...nt-7444na.html
https://vanquishauto.com/2016-nissan...bulb-7440.html
https://vanquishauto.com/2016-nissan...bulb-2825.html
https://vanquishauto.com/2016-nissan...-bulb-194.html
#64
Hey all - looking at getting my first Maxima. Fell in love with 8th gen and will be trading in my 2010 4Runner for one soon.
Do any of you know if it is just the Platinum that comes with the HID light setup? I am torn between the SL and Platinum and that could make me sway toward the Platinum.
Thanks in advance!
Thanks in advance!
YourLocalAsian
08-17-2015 02:33 PM
wingsfan24
08-15-2015 07:35 PM
Nintensity
08-13-2015 05:41 PM
