Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
03 I35 4AT Dyno
Old 02-22-2014, 04:41 PM
chakal95's Avatar
03 I35 4AT Dyno
I had a chance of putting my 03 I35 4AT on the dyno today. I am kind of curious to know why the difference between the max horsepower and the max torque since most dyno graphs i see here are almost the same. Also, can anybody confirm if these numbers seem right for my car and mods, i tried looking around but theres barely any auto dynos with no tune in here. Any opinion is appreciated. Thank you
max power was 209.52
max torque was 230.15
Mods are as follow:
Gutted precats and main cat
Custom Cold air intake with a aem filter on the drivers wheel well
CXJ 3 pcs Phenolic Intake Spacers
CXJ BOP
2 degree timing advance
Knock sensor resistor 560k ohms bypass
chakal95 is offline
Old 02-22-2014, 06:04 PM
LandShark has Cosworth
grey99max's Avatar
A dyno measures just torque. Horsepower is calculated from those numbers as: Torque X Horsepower / 5252. The two curves always cross at 5252 RPM on the dyno sheet.
Link:
http://www.epi-eng.com/piston_engine...and_torque.htm
grey99max is offline
Old 02-22-2014, 07:24 PM
chakal95's Avatar
Link:
Thank you for the explanation and the link.
chakal95 is offline
Old 03-05-2014, 10:36 AM
dot dot dot ...
NmexMAX's Avatar
Breathing mods tend to give more HP, at higher RPM's. I was similar to you when I first started, I was at about 210 and 225 or so.
Most recently I was at 257/245 or something like that, and as I tracked my progress, my hp slowly began out pacing my torque. 210/225, 233/230, 242/238, 247/242, 257/245.
NmexMAX is offline
Old 03-05-2014, 04:11 PM
chakal95's Avatar
From all the research i have done on the forums i think the only breathing mod i have left to do is a Y-Pipe and possibly changing out the gutted precast for actual headers, but i have read that the difference won't justify the price. From the numbers you told me i see you went from 210 to 233 which is a great jump, and the biggest of all, was this achieved tuning with a VAFC? i am hoping to get closer to the 240HP mark but i believe that i have to definitely have to move towards a VAFC to achieve this. Anyways that is a great car you have keep it up! Members like you inspired me to get into this maxima game!
chakal95 is offline
Old 03-05-2014, 09:40 PM
Quickywd01's Avatar
Wow no y-pipe.
Quickywd01 is offline
Old 03-06-2014, 04:59 AM
chakal95's Avatar
Originally Posted by Quickywd01
Wow no y-pipe.
That is why i didnot point it out on the first post, the only mods that the car has is what it says there... i think the #s seem right for those mods.
chakal95 is offline
Old 03-06-2014, 06:34 AM
dot dot dot ...
NmexMAX's Avatar
This probably needs an update and a cleanout but in any case, should help answer a few questions for you.
http://forums.maxima.org/dyno-discus...no-thread.html
NmexMAX is offline
Old 03-06-2014, 02:13 PM
Chocolate_Boi_1Der
Cant_Get_Ryte's Avatar
NMex is your huckleberry. Can provide you with a number to a local kid that has a cattman y pipe if you want
Cant_Get_Ryte is offline
Old 03-06-2014, 06:58 PM
chakal95's Avatar
When you say local what are you referring to? Miami, FL ? If so give me the number so i can ask pricing. Thank you very much !
chakal95 is offline
Old 03-06-2014, 07:29 PM
george__'s Avatar
**** I'm looking at ~260 whp with my mods then
george__ is offline
Old 03-07-2014, 12:36 AM
Fakie J Farkerton's Avatar
Fakie J Farkerton is offline
mclasser
22
11-12-2020 01:58 PM
Unclejunebug
04-02-2016 05:42 AM
maxinout93
10-31-2015 02:04 AM
Hdnseek
09-09-2015 05:55 AM
Quick Reply: 03 I35 4AT Dyno
