VQ35DE new engine break-in - why 3750 for the 1st oil change?
#42
Originally Posted by CBRworm
Do they really still use break-in oil?
Your lab results will show additives that look like "break-in oil" but its usually just the assembly lube that is mixed in with oil.
Changes mine at 1K, 5K with Dino oil
At 10K miles I put in synthetic blend
From 15K on its Mobil 1 full syn.
I drive a lot though so 5,000 is every 2-3 months for me
#43
Originally Posted by DARHAW-MAX
I guess I win the oil-change-frequency award. Regardless of miles, I always change the oil in my two Maximas and my girlfriend's G20 every payday (twice a month). During the winter months, I may do it once every month--depedning on whether or not I can withstand the weather conditions. Changing oil is like having money: you can never have too much.
#44
Hello there!!
Okay I would like to hear some experienced opinions from you more veteran guys out there. Thanks.
I drive 130 miles a day for my commute and work 4 days a week. Some weeks, 5. But mostly 4.
My car just hit 1200 miles today and the owners manual says thats the break in period.
My commute is 85% highway, so pretty much I'm cruising around 65-75 mph.
What intervals and what kind of oil do you all reccommend?! Thanks in advance!
#45
Originally Posted by stypa1
The number 3750 * 1.6 = 6000 Kilometers. That's why it is so funky.
#46
I am using the mobil 1 filter and mobil 5-20, at start up sometimes I hear the "rod knocking sound". Could this be from using the 5-20? I had thougt at 81k that the switch to a full synthetic would still be a good idea. Should I go to the 5-30 as others had suggested or stay with the 5-20? I want this car to last and will take any comments with a grain of salt. Also since I got the car at 81k, I have changed oil at 3750. The dealership i bought it from used motorcraft 5-20 blend and I thought the blend was just a myth for anything good. Someone want to elaborate for me.
#47
i have 2002 max SE how i know i have VQ35DE i won my oil and filter Chang i went auto zone and i asked for M1-105 and they say this to big you need M1-108. please some one help me out i am newbie and this is my first post
#49
oil is cheap if your considering keeping it for the long haul i
would change it 600 miles why? to drain the factory assembiley
lube thats still in there that nissan used for
lubing engine parts like your cam,
crank shaft,etc and not to mention the metal shavings that are
circulating in there.
MatthewsMaxima
09-11-2015 03:21 AM
maxinout93
08-20-2015 02:17 AM
