Fuel Tap - Wet N2O - 5th Gen DEK
Old 05-08-2012, 05:56 PM
MoncefA33's Avatar
Sup guys...
I am hooking up a DynoTune wet nitrous kit. I need to know what fuel line needs to be tapped (since it is return style) in order to finish the installation, and would I just be able to cut the line and use a barbed fitting?
Moncef
MoncefA33 is offline
Old 05-08-2012, 07:32 PM
036mtmax's Avatar
In for 3rd gear wheelspin vid when she's on the jug
036mtmax is offline
Old 05-08-2012, 09:56 PM
i30dvr's Avatar
i cut my hose right after the fuel filter about 4 inches up...i then added a y-barbed fitting with some new fuel injection hose and clamps...i'll see if i can find some pics
i30dvr is offline
Old 05-08-2012, 09:59 PM
MoncefA33's Avatar
You return style or returnless?
Old 05-09-2012, 07:48 AM
aackshun's Avatar
Paging grey99.........
aackshun is offline
Old 05-09-2012, 09:09 AM
LandShark has Cosworth
grey99max's Avatar
This ain't my thread - besides, these guys know what they're doing. You know me, I tend to make things complicated.
grey99max is offline
Old 05-09-2012, 09:54 AM
MoncefA33's Avatar
You make more than twice the power my car makes and you are tuned by teh tape.
Old 05-09-2012, 11:16 AM
grey99max's Avatar
Well, if I could get a real stand-alone ECU to connect to my 3.0 timing, I could get rid of the tape - and the rev limiter...... "so many projects, so little time.."
Old 05-11-2012, 07:36 AM
2000_MAXIMA_KING's Avatar
Wet N2O, YES!
A Z32 with stock turbos, stock injectors, stock engine, and off the shelf JWT tune (not even tuned for nitrous just higher rev limiter and a bit richer for higher boost, etc) just made 524Hp 584TQ with a wet n2o setup injected right before the throttle bodies into the plenum.
I'm looking into a setup myself for the track, just have to get some big maintenance out of the way first.
2000_MAXIMA_KING is offline
Old 05-13-2012, 11:33 AM
i30dvr's Avatar
return style
i30dvr is offline
Old 05-28-2012, 12:23 PM
wirelessdude04's Avatar
the 300zx has one clean a$$$ engine bay. Classy to hide the nitrious line under the wire loom
wirelessdude04 is offline
Old 11-27-2012, 12:49 AM
Quickywd01's Avatar
Quickywd01 is offline
Old 05-16-2013, 07:12 AM
TravisCadello's Avatar
No Fuel Filter on 5th Gen....
TravisCadello is offline
Old 05-16-2013, 07:13 AM
I got same question need to kno where to tap for Fuel on a NX Kit.
Old 05-16-2013, 08:19 AM
streetzlegend's Avatar
Just tap into the line that goes right before the fuel rail. The goal is to tap into the line before the FPR, because if you tap after it, you wont be getting the correct pressure.
streetzlegend is offline
MAXSE5SPD
09-17-2022 04:00 AM
aminus21
09-12-2015 04:53 PM
Violator
09-09-2015 10:14 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: Fuel Tap - Wet N2O - 5th Gen DEK
