Wheel Offset and Tire Size Calculator Thread - LOOK!
Old 08-25-2003, 08:08 AM
Ad·min·is·tra·tor
DanNY's Avatar
thanks to those guys at the miata site.
plug in the numbers and you can determine if the tire size is right for you.
http://www.miata.net/garage/tirecalc.html
DanNY is offline
Old 08-26-2003, 07:44 AM
Ad·min·is·tra·tor
DanNY's Avatar
http://marksink.com/tire_wheel_offset/
DanNY is offline
Old 02-15-2004, 01:54 PM
Ad·min·is·tra·tor
DanNY's Avatar
another calculator:
http://www.1010tires.com/TireSizeCal...?action=submit
Thanks to SG01MaxSE
DanNY is offline
Old 04-30-2007, 06:21 AM
Ad·min·is·tra·tor
DanNY's Avatar
http://www.rims-n-tires.com/rt_specs.jsp
DanNY is offline
Old 02-18-2009, 05:12 AM
Puppetmaster's Avatar
One more courtesy of diverdown3:
http://www.wheelsmaster.com/rt_specs.jsp
It is the same as the one above, but has a different URL, so just for back-up I guess.
Puppetmaster is offline
Old 10-26-2010, 01:08 PM
dot dot dot ...
NmexMAX's Avatar
A touch more informative as well as 'modernized' from DennisMik
http://www.discounttire.com/dtcs/infoTireMath.dos
NmexMAX is offline
PH98I30
26
10-12-2015 05:01 AM
maximusrising
09-02-2015 09:55 AM
coasterswim
09-02-2015 07:43 AM
Cant_Get_Ryte
08-28-2015 06:41 AM
maximaham
08-20-2015 10:23 AM
Quick Reply: Wheel Offset and Tire Size Calculator Thread - LOOK!
