1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
13.5 @ 90mph, is there any way to figure out what i COULD have run?
Old Nov 13, 2002 | 03:20 PM
hlh0501's Avatar
I ran a 13.5 @90mph when attempting too high of boost for my stock clutch, and it finally slipped to redline and i had to shut it down and not finish the run.. hence 90mph trap. Is there anyway to compute approximately what i would/could have run ? thanks in advance.
Old Nov 13, 2002 | 03:25 PM
Jeff92se's Avatar
I'm needing a caw
Wow. You need a clutch bad! Well I suggest emailing Stev. He's the graph/hp/1/4 dude! lol
Old Nov 13, 2002 | 03:27 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: 13.5 @ 90mph, is there any way to figure out what i COULD have run?
where's the rest of the slip?
did you shut it down before or after the 1000'mark?
Old Nov 13, 2002 | 08:35 PM
Victim64's Avatar
Hard to say without the rest of the numbers. mid to high 12's??
oh, I will be there this saturday. : )
Old Nov 13, 2002 | 10:02 PM
nismo2020's Avatar
Needs non-Maxima Friends
well a 13.5 is in the area of 102+ mph traps. if i were you i would look at other 1/4 times and guesstimate the speed for a 13.5, with a good clutch (ACT) im sure you can clipse between a 13.0 and 13.2
Old Nov 14, 2002 | 08:13 AM
deezo's Avatar
I'd say somewhere in the 12's.
Old Nov 14, 2002 | 08:37 AM
Victim64's Avatar
Yeah, that sounds like a good guess!
Old Nov 14, 2002 | 03:55 PM
SmoothMax's Avatar
OG
If you had coast to the end of the track and ended up with 13.5@90, I'd say high 12's w/out slicks and mid 12's w/slicks both w/a good clutch. Impressive.....
Old Nov 15, 2002 | 09:57 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
it's all speculation until we find out where he STARTED to coast from...
Old Nov 15, 2002 | 10:35 AM
Cumalot's Avatar
Man, if I have a 5spd and the money, I would buy your turbo kit in a heartbeat.
Old Nov 15, 2002 | 07:13 PM
Nealoc187's Avatar
SLOW
How was your run for the first 1/8th mile?
1/8 mile x 1.56 = 1/4 mile time, thats the normal convention. 1.57 multiplication factor is on the conservative side, 1.55 is optimistic, so depending on how good your 1/8th was you can judge by that. Was the first 1/8th mile clean?
Old Nov 18, 2002 | 10:32 AM
ejj's Avatar
ejj
Had to be to run a 13.5. I've seen much faster cars shut down around the 1/8th mile mark and coast to worse times.
Old Nov 18, 2002 | 04:10 PM
SuDZ's Avatar
Now that his car is going in for that clutch it should be intresting to see what he can run, especially is he uses the 245's over the 225.
SuDZ
Old Nov 20, 2002 | 07:02 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
13.5 @ 90
yeah, extrapolating from the 660' time/speed is probably as good as anything, as neal already posted.
Not sure if you ever posted a dyno chart for your setup or not, but if you have one, email it to me at SteVTECv6@yahoo.com and I'll enter it into CarTest2000 to see what the max potential of your car is.
Old Nov 27, 2002 | 07:21 AM
Jamsan's Avatar
12's would be sick
Old Dec 13, 2002 | 03:32 AM
BULIITT's Avatar
here it is again speed as you can see has nothing to do with the E.T prime example you ran a 13.5 at only 90 which shows that you had to lift and shift. I dont like using the term shut down or back off when it comes to imports sorry.
once again. you can run at 115mph and still be stuck in the 13's
things that matter are can you drive the car, can you get off the line are you spinning, 60ft times are the key
get the car into the 1.7 to 1.9 60 ft times and see what your ets are.
Old Dec 13, 2002 | 01:55 PM
F23A4's Avatar
Yeah, anyway......YOW!!! 13.5!!! Pretty impressive, bro.
Old Dec 13, 2002 | 04:57 PM
Nealoc187's Avatar
SLOW
What kind of a statement is that? Since when does where your car was manufactured have anything to do with lifting off or shutting down early, and what name you give it?
Old Dec 15, 2002 | 08:02 PM
nismo2020's Avatar
sure buddy
Old Dec 17, 2002 | 06:56 PM
CARIZMAX's Avatar
How much boost were you running on that run?
Old Dec 21, 2002 | 11:12 PM
JAIMECBR900's Avatar
Hey cletus....do your buddies know you waste your valuable time posting in an import forum??? Would you lose your status in the tree house if they did???
The question was what would he have run on THAT particular run had he NOT had to back out of it. Do you have an answer brainiac? If not, go post ***** in a rustang site somewhere. If you do, post it so we can see how totally brilliant you are by making such new earth discovery comments like "lower your 60ft times and you'll get better et's". DUHHHHHHHHH!!!!
Old Jan 3, 2003 | 04:17 AM
thnikkamax's Avatar
Ludicrous Speed
yep yep... dem there domestics sunny, ah'd hate tuh use the werd shut dow on a domestic.. sorry.. more like whoah nelly, or a thang in the likes of bring them there hoss to a hault.
Anyway.. Harold, I'd love to see what happens if you don't shut down. 12.3 is my guesstimate.
captchaos
Mar 15, 2016 12:18 PM
Max139617
Sep 20, 2015 07:09 PM
ballerchris510
Sep 10, 2015 09:35 PM
trungg86
Sep 4, 2015 04:58 AM
A32goldylocks
Sep 2, 2015 06:39 AM
