1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Racing slicks..weight issue as well?
Old Jan 7, 2003 | 01:57 AM
thnikkamax's Avatar
Ludicrous Speed
Hi all, I have a question about racing slicks..
A lot of people mount these on the stock front steelies, but are there any lighter OEM steel rims on other cars that will fit a 4th gen as well? Also, since you have slicks, would it be better for the rim to be lighter, or the stock weight is fine for traction? I know i could go with small aftermarket lightweight rims but it's a money issue.
Thanks,
Mario
Old Jan 7, 2003 | 05:20 AM
Jime's Avatar
Re: Racing slicks..weight issue as well?
Thanks,
Mario
The lighter you can go the better. However its not easy to get a light wheel without paying big bucks. The mazda millenia is nice and light at 11.5 lbs but its only 6" and most slicks require at least a 7".
I am in the process of doing the same thing but haven't found a cheap solution yet.
There are expensive solutions ie Hart's etc but I am not ready to give in yet. I also want a set for the rear to get rid of the weight there too, and some nice light skinny tires to go with them.
Old Jan 7, 2003 | 11:54 AM
thnikkamax's Avatar
Ludicrous Speed
Re: Re: Racing slicks..weight issue as well?
Sometimes i wish our 4th gens were 4-lug. I see so many 14.5-15sec civics that have awesome 60' because of their lightweight cars and the small rims with slicks. Sometimes I think that Nissan definately didn't want aftermarket support for these cars.
Old Jan 7, 2003 | 12:52 PM
Nealoc187's Avatar
SLOW
Contrary to popular belief, wheel weight has nothing to do with traction, so don't make the mistake of thinking a lighter wheel makes for less traction, it doesn't.
Anyhow, Mazda Millenia wheels are very light but fairly narrow at only 6" wide. I know of at least 2 slicks that will fit on them though.
Old Jan 7, 2003 | 01:48 PM
WizzaMax's Avatar
I run the BFG G-Force T/A drag radial in 225/50/15 on the stock steelies and they weigh in at 40 pounds total ... 2 lbs more than the stock tire sizes...but it works so I don't care...
Old Jan 7, 2003 | 03:16 PM
Jime's Avatar
My old 15" alloys ran 19 lbs.
My 205x45x15 Nitto 555r's weigh 17 lbs.
My 22x8x15 slicks weigh 11 lbs
Total of 30 lbs for racing but if I had 11.5 lb Millenia wheels the total would only be 22.5, but thats for this racing season.
Just have to find the wheels.
Hmmm maybe I should just lose 20 lbs, maybe I should do both. How about helium vs air in the tires?
Old Jan 7, 2003 | 05:17 PM
Nealoc187's Avatar
SLOW
I always wondered about that...
Old Jan 7, 2003 | 07:47 PM
Aaron92SE's Avatar
NWP Engineering.com
Does anyone know if it's possible to fit 14" 5 lug wheels on my front?
Old Jan 8, 2003 | 04:31 AM
Jime's Avatar
Tried that Aaron, won't fit over the brake disk on 4th Gen. I was going to do that last year. Not sure on other gens though.
I don't think I want to go any smaller now anyway, we have one track that has a rough return road and I bottom out all the time so its pretty low. Lowering springs did that mostly though.
I also have to get someone lift up on the front fender to get the jack under now when the 22" slicks are mounted, so I can't change tires myself anymore.
Old Jan 8, 2003 | 09:15 AM
MardiGrasMax's Avatar
Kosei K1's 16lbs in 15x7
Old Jan 8, 2003 | 09:20 AM
Aaron92SE's Avatar
NWP Engineering.com
Stock 3rd gen SE wheels 18lbs in 15x6.5
Old Jan 8, 2003 | 09:37 AM
Nealoc187's Avatar
SLOW
13lbs in 15x7. They are 16 and change in 17x7.5
Old Jan 9, 2003 | 09:25 AM
ejj's Avatar
ejj
I was able to find a set of 15X7 RX-7 rims (dunno what year they were from) that weigh no more than 15lbs each on eBay. Might be worth a shot to search for.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
MplsMadMan
Sep 11, 2015 07:54 AM
