1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
stall converter question
Old Mar 28, 2003 | 04:52 PM
mayhemI30's Avatar
"I'm running with scissors!"
im gettin a stall converter from level ten installed on April 7th.
just wondering if anybody has an aftermarket one. i need a little info so i know what to expect.
Old Mar 31, 2003 | 05:51 AM
Larry's Avatar
Expect a lot more acceleration! Assuming you have traction and your shift points don't raise and your engine hits the revlimiter before shift. I'm afraid you will need re-programming for a converter to work with our transmissions.
If you are looking for maximum acceleration you will need a 3900 rpm stall converter. Our engines make max torque at 4400. Maximum acceleration is attained around 500 rpm blow max torque. Of course the looser converter you get the higher the rpm will go under part throttle acceleration. A good street converter would be around a 3000 stall. Don't get too loose a converter or you will be sorry later on.
Traction will be a major concern. You will need some real sticky tires or even slicks to hold traction. Particularly with our front wheel drive.
Good luck and let us know how you come out.
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Socalstillen
Sep 26, 2015 12:01 PM
