1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
2k 5spd w/ y-pipe, injen intake, udp.
Old Oct 11, 2003 | 06:24 PM
purekoryo's Avatar
hey guys, what would a 2k 5speed gxe run in 1/4 mile with y-pipe, injen intake, and udp? this is going to be my frist mod after i sell my old car...i just got this maxima...also, im assuming that the rsb won't do much in 1/4 mile but only just handling? i'm trying to mod my car to hit 14.5 in 1/4 mile and i just wanted to know what would be the best bolt-on's to achieve that time....reponses would be much appreciated.
Old Oct 11, 2003 | 09:17 PM
purekoryo's Avatar
c'mon guys..i know one of yal must know..i've already tried searching...
Old Oct 11, 2003 | 11:43 PM
1BADMAX's Avatar
The mods you mentioned should got you right at a 14.5 and maybe less providing that you get good 60ft times. If you want to see what times people have gotten. Look here. Hope this helps.
http://forums.maxima.org/forumdisplay.php?f=46
Old Oct 12, 2003 | 07:03 AM
purekoryo's Avatar
Thanks a lot!
Old Oct 12, 2003 | 08:24 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i think it depends ..it may take the addition of an upgraded ecu plus those mods to ****** 14.5
i believe the weight would hold you back, going on the assumption that your car is heavier than a 4th gen. Also tires/rims are important too ! If you have 17's or anykind of aftermarket wheels that are not light it will hold you back.
what you think ?
Old Oct 12, 2003 | 05:12 PM
91 EX-R's Avatar
Have you tried running the car stock yet to see how far you are from your goal?
Old Oct 12, 2003 | 09:12 PM
Dave B's Avatar
Not DAVEB the parts guy
I don't think he's owns a Maxima anymore, but a guy down in FL had a 01 5 speed SE with a Place Racing CAI and y-pipe and he ran 14.3s@96mph with a 2.1 60' on the stock 50lb 17s. It is possible. Rare, but possible assuming you can get off the line with a 2.1 60'.
Dave
Old Oct 13, 2003 | 04:44 PM
3.0HO
Dave
A weird trend I find is that not too many 5th gen 5spds even run at the track. A handful at best. Even that guy Russ broke into the 14's without a y-pipe. I think if more guys went and practices there woud be a difference.
Old Oct 13, 2003 | 05:49 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
A lot of the 00-01 guys either went boost or traded for 2k2's. You're right, there's not a lot of them that track their cars. They're a lot heavier and have relatively less low-end torque which makes them more difficult to launch, especially with the 17" rims. They can get the same tims as 4th gens can, but it takes a lot more driver skill to pull it off. The ones with 15" steelies (GXE) or 16" alloys delete the heavy wheel issue and are a bit quicker.
Old Oct 17, 2003 | 06:37 AM
190hpKiLLA's Avatar
Granny Driven
I think they are just as fast. I ran a 14.83 with intake with 2.2 60 foot. I think i can get into 14.7 with better launch.
Quickywd01
Sep 21, 2016 09:36 PM
ef9
Oct 4, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
