1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
how much air to let out of 18-40s
Old Apr 5, 2004 | 06:21 AM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
heading to the the track on thursday for a run on my 18s...
how much air should i let out of my tires... specs of tires in sig
thanks
2k2PhatMax's Avatar
i thought specs were in there... 235 40 18
Old Apr 7, 2004 | 08:33 PM
2k2PhatMax's Avatar
bump anyone?????
Old Apr 7, 2004 | 09:30 PM
I30tMikeD's Avatar
start out with regular tire pressure and go from there.
Old Apr 7, 2004 | 09:34 PM
2k2PhatMax's Avatar
been there done that... i am wondering what to lower them to... from people with experiance
Old Apr 7, 2004 | 10:03 PM
I30tMikeD's Avatar
The whole point in lowering tire pressure is to try and get better traction. So if your spinning the regualr recomended PSI and the tires spin really, really easily then dropping the PSI a couple lbs and run again. If you still think your gettin too much spin drop them another couple lbs. There is no set amount that is recomended to drop your psi to and there is a point at which your traction will get worse because there is not enough air in the tire and the tread no longer fully contacts the ground. I run 24-30 psi in my 15's at the track, but that is just me.
But your always going to get spin with the kind of torque a 5th gen max has. So it's more a skill of easing into the throttle to the point where you put down the most power without losing traction. If you just punch it your going to spin your tires no matter what.
Old Apr 8, 2004 | 08:40 AM
2k2PhatMax's Avatar
ok... thanks... i was basically wonder what not to go lower than... just so i dont F something up
Old Apr 19, 2004 | 02:58 PM
hhsguy150's Avatar
h
Old Apr 19, 2004 | 03:50 PM
2k2PhatMax's Avatar
go to halls... its the knoxville dragway... get on broadway take it past halls into maynardville and it will be on ur left way out there... ull see all the imports driving just follow them... on thursdays...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
