1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
16" Drag slicks from M&H
Old Jul 9, 2004 | 11:17 AM
Nealoc187's Avatar
SLOW
found this thread on the the RSX forum, they are trying to get a custom run of 16" slicks made, because 16" slicks basically dont exist, and if they do, I sure havent seen any that will come close to fitting a max.
http://forums.clubrsx.com/showthread.php?t=143524
just a heads up for you 5th gen guys who cant put 15s over your front brakes.
Old Jul 9, 2004 | 11:28 AM
Blu's Avatar
Blu
the tits
15's fit just have to have the right wheel/offset. Myself and Jime both run 15" wheel setups.
Old Jul 9, 2004 | 03:16 PM
Nealoc187's Avatar
SLOW
i knew you both were running 15s but somewhere along the line i got the impression that both of you had done a 2k1 brake swap so that you had small enough rotors and enough clearance from the caliper to run them. i must be crazy.
Old Jul 9, 2004 | 04:03 PM
Jime's Avatar
Well Neal they just fit, clearance is really close but no brake swap.
Old Jul 10, 2004 | 07:06 AM
Blu's Avatar
Blu
the tits
hehe....I might have a passion for drag racing but swapping to smaller brakes that sounds scarey. As Jime said there is probably only an 1/8" gap in between the ID of the wheel and the caliper. Its a tight squeeze but we made it work .
Jim what is the offset on your K1's? I need to order a set from tirerack but I want to make sure they carry the correct offset to clear the 02-03 brakes.
Matt
Old Jul 10, 2004 | 08:16 AM
Jime's Avatar
I'm not sure Matt, I think they are 35 but I got them used from a fellow org member in Wash State.
Just checked they are +38.
Old Jul 11, 2004 | 05:43 PM
Blu's Avatar
Blu
the tits
Thanks man that helps a lot. Now I know exactly what needs to be ordered.
Old Jul 12, 2004 | 05:52 AM
Nealoc187's Avatar
SLOW
are they kosei k1s? did you get them from a guy named global_threat? if so those wheels used to be mine hehehe
Old Jul 12, 2004 | 11:14 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Kosei K1 in +38mm work just dandy Light, and inexpensive!
Old Jul 12, 2004 | 01:19 PM
Jime's Avatar
The guys name was Casey F not sure his org name Neal.
Maxima_Joe
Nov 25, 2015 08:19 AM
VQ'ed
Aug 30, 2015 05:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
Xi MaX SC
Aug 7, 2015 08:47 AM
