Launching
unfortunately no one is caring, I'm just trying out how to launch better because I suck. I can't break 2.4's. I only have once. I try launching at 2500 rpms and I think that is a good rpm for me but I suck at modulating the clutch.
Luanch technique: Spin 2-3 sec to clean tires. Slip @ 2200rpm ~70% throttle and clutch moving smoothly to 100% in about 1.5 sec.
Last 23 60's: 2.217, 2.205, 2.200, 2.174, 2.170, 2.208, 2.212, 2.181, 2.207, 2.199, 2.230, 2.223, 2.165, 2.245, 2.249, 2.162, 2.216, 2.231, 2.271, 2.261, 2.303, 2.253, 2.196, and 2.248.
AVG: 2.218
AVG: 2.218
I feel this question is a little bit on the broad side. I do a dry burnout first for a second or two to remove all the derbis off the tires. But the way i launch, I brake torque at 1400, as soon as I feel the car grip...then I press the gas pedel all the way down. I usually pull a 2.250 to 2.3 60's on street tires. The reason I said this is kinda a broad is because the tires you have on, the tire pressure, rim and tire size, if you are lowered and have adjustable struts/shocks the settings of that, can make a difference in the way you launch. Everyone launches differently, just keep practicing you'll figure out what is the best way to launch with your current settings. Good luck
As for tire pressure I'm just assuming that those with street tires would be using 25PSI in the front tires. I have read tons on launching. I have been launching at 2500 rpms and getting 2.4 60', one time I got a 2.3. Anyhow
I'm just trying to see if the majority launch at higher rpms like around 3000 or if they launch close to where I launch.
I've found that pwr braking just causing my tires to spin. Although the last time I went racing I had zero traction (78degrees, 95% humidity 1200ft elevation) I ran
10) 15.1@91mph and 1) 15.8@86mph (spinning) my best 60ft was 2.2 I think. And I tried various launching techniques but the humidity really kills my car. (03 SE auto).
btw no one was at the track that night either I got those 11 runs in in less than 2hrs AND I sat around awhile between runs to let my car cool.
Keven97SE
Dec 6, 2000 01:45 PM
JimW
Nov 20, 2000 05:57 AM
