1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
auto guys..how yall launch at the track?
Old Sep 12, 2004 | 11:52 AM
joosdawg's Avatar
ok in various posts ive noted that i have crappy time slips and i think most of it its due to my launching. what i do is tourque brake the gas to the floor(usally around 2300rpm) and the brake as hard as i can and just let it go at the 3rd yellow. mind you i dont have a r/t problem those are almost perfect its just the fact that my 60 ft times are like 2.4X crappy. i would think that launching how i do would be faster than tourquing to say 1600rpm then flooring it while simulatiously letting off the brake, or am i wrong to assume that? also i always have little to no wheelspin off the line when i launch but it seems most people at least spin some of the time, where as my car most of the time just goes and doesnt spin(not that thats not a problem ). so how do the fellow auto tranny guys launch? my way or less rpms? thanks -ryan
Old Sep 12, 2004 | 11:57 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
first i do a quick burn out. then i get up to the line, wait for the 2nd yellow light and just floor it. Make sure your O/D is off until around 60Mph.
Old Sep 12, 2004 | 12:20 PM
Tyrexx's Avatar
o/d off won't do anything, unless you get over 120mph
Old Sep 12, 2004 | 01:27 PM
joosdawg's Avatar
whats some et's you have gotten with this method? the 2nd light seems kinda early but i spose i could try that. anyone else? -ryan
Old Sep 12, 2004 | 04:02 PM
95nissanMax's Avatar
keep overdrive off the whole time no need to shift into 4th u can get up bout 126 in 3rd i know first hand.
Old Sep 12, 2004 | 04:45 PM
aznprid972's Avatar
ill doubt your trapspeed will be anywhere near 126mph anyways. just keep it in D because youll be somewhere in 3rd by the time you pass by.
Old Sep 12, 2004 | 04:47 PM
Loe max's Avatar
If you keep O/D off, the TQ converter will lock-up around 78-82mph in 3rd gear.
Old Sep 12, 2004 | 06:27 PM
naijai's Avatar
Truth Totally agree
Old Sep 12, 2004 | 07:31 PM
what do you mean by this please explain
Old Sep 12, 2004 | 08:54 PM
SSjTrunks112O's Avatar
true, if ya keep your OD off, you can get up around 125mph, and just before redline(6500rpm), switch OD on, this way you can get into the high 130's close to 140mph depending on your car.
Old Sep 12, 2004 | 09:52 PM
THT's Avatar
THT
Throbbing member
You won't get close to that speed in the 1/4 so why bother?
~THT
Old Sep 13, 2004 | 09:29 AM
joosdawg's Avatar
~THT
ditto.
exacly what does that have to do with launching also?
Old Sep 13, 2004 | 05:44 PM
deezo's Avatar
Put the car in D and leave OD off. Torque brake just as you hit your mark and on the second yellow, mash the accelerator to the floor while releasing the brake at the same time. To make the tranny shift faster just feather off the accelerator at redline.
Old Sep 13, 2004 | 06:01 PM
joosdawg's Avatar
but i have the drop resistor to shift faster so i dont think it matters plus i would totally redlight launching at teh 2nd yellow i got a damn r/t of .008 going on the 3rd yellow on a .000 tree but my point is my car is hella slow for some reason off the line idk
Old Sep 13, 2004 | 06:20 PM
stephenlc's Avatar
who cares what your reaction time is. They do not consider it for 1/4 mile time.
Old Sep 13, 2004 | 06:22 PM
joosdawg's Avatar
i do because im sayin my car does move off the line but after that it like dies idk how to explain it
Old Sep 14, 2004 | 06:15 PM
deezo's Avatar
You could sit on the line for 1 hour and your 1/4 will be the same. RT's don't matter.
Old Sep 14, 2004 | 06:19 PM
joosdawg's Avatar
yes i understand that guys i guess im just saying somthing wrong in asking my question so i guess nvm that and i just wanna know if powerbraking to like 1600rpm and flooring it at the same time as letting off the brake is the fastest way to do it?
Old Sep 17, 2004 | 05:48 AM
TAPOUT's Avatar
You will lose
Leaving the line at a higher RPM is better, especially with an auto. Our cars take a while to spool up in 1st gear. The trick is not to spin, even a little from the line. The Max should be able to get a 2.3 60 ft with no problem. When I launch, I slowly press the gas to the floor. If I mash it to the floor, I just spin. I went out and bought a G-Timer from Escort, and it really helps you learn what is faster. Try different methods, and see what works best for you. I have run as fast as 2.15 for 60 ft, with street tires, and no N2O. You just have to learn what the traction limits are, and be right on the line between a clean launch, and spinning to hold these times. Practice is the only answer.
Old Sep 19, 2004 | 02:21 PM
MrDicks95SE's Avatar
Offset Is Everything.
would it help to torque brake and rev the engine at a higher rpm and then launch?
Old Sep 20, 2004 | 04:57 AM
Jime's Avatar
I get my best 60's from this method. Foot on brake, rev to approx 900-1000, leave on last yellow.
Old Sep 28, 2004 | 02:09 PM
tedo007's Avatar
faster than you think
well i jus floor it enough so it wont spin and the best 60ft i got is 2.3 and 1/8 is 10.1 i know i can get better.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
BobTX10
Oct 7, 2015 08:43 AM
