1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Automatic
Old Feb 8, 2005 | 06:14 PM
konak85's Avatar
Automatic
I've got an auto GLE and i'm interested in the best method to race it to get better track times. Power brake or not? Use the 1 and 2 on the shifter or not? Thanx
Old Feb 8, 2005 | 06:17 PM
5thgen2nr's Avatar
I brake-torque to about 1300 or 1400 rpms, and I do manually b1tch-shift the auto tranny...even if it doesn't improve my times, it makes me feel better about it lol.
Old Feb 8, 2005 | 09:05 PM
tavarish's Avatar
fwd gone rwd cr00
leave it in D, brake torque to 1500, go on the last yellow after staging...
do a few mods to help you along, like the hacked airbox mod, and take out your spare tire and anything else you can to lighten the load. also, let the front tire pressure be around 20-25 psi to improve traction. It's not necessary to do any burnouts on street tires when you're stock, only warm them up when you have slicks, so drive around the water box.
Old Feb 9, 2005 | 07:12 AM
C MAX's Avatar
[QUOTE=tavarish]leave it in D, brake torque to 1500, go on the last yellow after staging...
QUOTE]
ah an experienced auto racer. this seems to be the best method for me also.
Old Feb 9, 2005 | 08:49 PM
konak85's Avatar
Thanks for the input guys
Old Feb 10, 2005 | 05:49 AM
TAPOUT's Avatar
You will lose
If you put a big brake kit on your car, you can power brake to 2100RPM, let off the brakeat the last yellow, and nail it. Best thing to do is get one of those little g-timers, and practice your launches. It will tell you what is fast and what isn't. A lot of the time, what you feel to be fast, and what actually makes better time are two different things.
Old Feb 10, 2005 | 07:01 AM
C MAX's Avatar
yeh i need some of those, i start to creep after 1500. and your right some of my fastest times came from a seemingly slow start compared with some of my ferocious launches which yield low times.
Old Feb 11, 2005 | 08:07 PM
konak85's Avatar
Some reliable source told me that many times an auto can be faster than a 5spd if driven the right way. Whats your take?
Old Feb 11, 2005 | 10:24 PM
subs1000w's Avatar
the statment above only applies to cars with very high HP
there is a reason the only NA max in the 12's and the only boosted maxs in the 11's are all manuals although there are some very fast auto max but if they were swaped to 5spd with an EXCELENT driver i believe they would be slightly faster
Old Feb 12, 2005 | 12:18 AM
steaLthyMax's Avatar
given the same power, an auto CAN be faster simply because there is lack of human error. You step on the gas, the car goes. But with a manual, a driver can get a bad launch or misshift or miss a gear causing a slower time.
Old Feb 12, 2005 | 09:00 AM
SSurfer's Avatar
What if you cant avoid all the water, a short burn out? short hop?
Old Feb 12, 2005 | 09:22 AM
s0ber's Avatar
You can avoid the water O_O
=D
Just dont hit the wall while doing it.. Seen it happen before..
Old Feb 12, 2005 | 12:15 PM
konak85's Avatar
Simple, you can't shift faster than computer controlled auto transmission.
Old Feb 12, 2005 | 12:46 PM
maxboogie's Avatar
i have to agree to a point. yopu cant manipulate the hp with a auto unless you have a stall converter to achieve those times, but a properly boosted auto like c-max's you can see some quick numbers.
Old Feb 12, 2005 | 11:37 PM
5thgen2nr's Avatar
In theory, the manual transmission is faster than the automatic...however, theories don't bring human error into account...in a perfect world, the manny is faster than the auto, but not everyone is a perfect driver.
Old Feb 12, 2005 | 11:43 PM
RacertilTheEnd's Avatar
If you are going to race your auto, do not b!tch shift it. I can tell you from personal experience that it is a good way to fry your tranny. I fried the tranny on my camaro by doing that, and my brother fried the tranny on his avalon too. The auto tranyn is made to shift at certain points, just keep it in drive.
Old Feb 14, 2005 | 10:49 AM
RaceProfessor's Avatar
I've noticed zero difference with manually shifting the auto than leaving it in drive. I think with moderately fast cars, the manual would fare better while really high hp cars would benefit with a properly set up auto. High stall, torque convertor, shift kit, etc. Alot more consistent.
Sam
Old Feb 14, 2005 | 12:17 PM
C MAX's Avatar
heres a good little article on a friend of mine who turned me on to automatics. he made my car into a but whipping automatic
http://www.nhrasportcompact.com/2002/news/041901.html
Old Feb 14, 2005 | 02:15 PM
BLUEMAX01SE's Avatar
you need to auto shift that puppy- which means you shift 1st, 2nd, and up to D which is your 3rd gear- you'll never reach 4th in the 1/4 anyway so right as after you hit third you should be coming to the 1/4- i got better times when i shifted instead of just leavin it in drive - you can brake torque at the line til about 2000 rpm due to the rev limiter - unless you have a line lock on that puppy but then you'd be dreamin
Old Feb 16, 2005 | 11:03 AM
tedo007's Avatar
faster than you think
brake torque dont work right for me so i jus punch the gas and i get better timing i punch it as much to chirp not to spin
Old Feb 18, 2005 | 11:14 AM
5thgen2nr's Avatar
Oh yeah and one more thing...no matter if you leave it in D or do the 1 2 D thing, take OFF the o/d.
Old Feb 19, 2005 | 09:52 AM
tavarish's Avatar
fwd gone rwd cr00
get a 5spd....that's what im gonna do.,..i've just gotten tired of the auto, no fun to race anymore..
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
2kmaximel
Sep 16, 2015 03:19 PM
