1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Will this help me in the 1/4 mile?
Old Jul 21, 2005 | 12:01 PM
slammed's Avatar
http://www.drivetrain.com/autotransp...20Valve%20Body
would this help me in the 1/4 mile....if so, how much?
how much to install?
thanks
Old Jul 21, 2005 | 12:03 PM
Kevlo911's Avatar
Kevlo for President
It wont help too much but it will make the car better to drive and make hte tranny last longer
Old Jul 21, 2005 | 12:07 PM
slammed's Avatar
K87944C
Corrects / Prevents / Reduces: Prevents direct drum blowout caused by runaway line pressure. Burned 3 - 4 clutches. No 2nd. No 3rd after 3 - 2 or 4 - 2 kickdown. Direct clutch (3rd) inner seal leaks, wears or opens up due to rotating force. Corrects long or soft 1 - 2 and 2 - 3. Has High-Temp low shrink rings
$99.39
Im guessing I need to take out the whole tranny for this
Old Jul 21, 2005 | 06:19 PM
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by slammed
K87944C
$99.39
No, you would only have to remove your valve body. Simply remove the tranny pan, remove the valve body and then take the valve body apart and hope it all works when you put it back together.
I would highly recommend that you don't attempt this yourself. I would only trust Maximum Tuning or Rob at NRH to do this. They have both proven themselves to make their customers happy with valve body recalibrations.
*edit: Oh yeah, don't expect this mod to help your 1/4 mile times at all unless you are really pushing some power (280+fwhp). I didn't shave any more than a tenth in the 1/4 mile. Also, if you chose Max Tuning or NRH to mod your VB, then expect to pay a little over $300.
Old Jul 21, 2005 | 06:47 PM
slammed's Avatar
Im better off with a torque converter though...right?
thanks for your reply!
lrb6805
Sep 30, 2015 08:12 AM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
hntwhttail
Sep 12, 2015 03:43 PM
ag90fox
Sep 9, 2015 12:22 PM
