Best 60' on Drag Radials?
Originally Posted by Jime
Actually there is no nitrous in the air in Canada but there is a lot of methane which could account for the good times.
PS The methane is created from all the chicken sheit we have to put up with here.
Originally Posted by grey99max
Part of an earlier post...
Then I did something stupid. Feeling brave ( the plugs were all normal after the first two runs) I set the second stage to 100-shot, with a fat fuel jet (normal 52/31 - set to 52/38) and after launch with a 2.255 60' something broke around the 1/8 mile mark and I sputtered through the traps at 14.389 and 87.71 MPH. Two plugs, #4 and #5, were melted off but replacing them didn't fix the bad cylinder, so I drove home 90 miles on 5 cylinders. Bummer.
I picked up the '98 Max motor Saturday, and strapped it in my '93 Nissan pickup and came home. Later I pulled all the plugs on the '99 Max and did a compression check. The plug from Cyl 4 was wet with gas, and that cylinder has NO compression. Others were 190-210. Looking in the hole with a bright light show the piston top intact, with a black coating. No visible damage. I pulled the injector plug, and the Max starts and runs on 5 cylinders OK.
I'm taking the Max and the motor to a local speciality shop on Monday and get a valve repair or swap the head, depending, since I've got parts now... Gotta get back out there.
Nissan did install 3.0 V6s in the pickup, but probably not FWD VQs. Otherwise, the '98 VQ on nitrous in the little pickup could be fun.. No, I've gotta have SOMETHING dependable for work.
Sunday:
Originally Posted by Dave B
I think it would be cheaper and more reliable just to swap in the new motor. I wouldn't even trust Nissan to do a good job on a head swap. There's just too much involved. Swapping motors should cost about the same.
That's my first thought - the reason for buying the '98 engine was to have choices. I'm going to get a second (and maybe third) opinion first, though. It SEEMS like just one or both exhaust valves melted in the #4 cylinder, but there might be more damage.
Incidentally, this motor came from an insurance-total white '98 GLE with full grey leather interior. It was rear-ended, so most of the interior seems OK and it was all there. It's at Denton Auto Salvage in St. Mary's KS (http://www.dentonauto.com/ ), about 25 miles west of Topeka on Highway 24. For a small town, they seem like real pros, and deal mostly with insurace totals, from walking through the yard to see my donor Max.
I just ordered a VLSD automatic from a '99 Infiniti I30 with 37K miles on it, and the driver's side axle with it. It should be delivered by truck from Kentucky to the local shop on Friday.
I'm dropping off the '98 Max engine there tomorrow, so the shop should have the major parts they need to swap out the engine and transmission in one package.
Dave B, the owner said that 90% of cylinders that burned off valves have cylinder-wall damage and would have to be torn down and rebored at a minimum. (and they build a fair number of race cars - he drives a SC Mustang that I have seen run a 12.1ET 122MPH). You were right - an engine swap is definitely indicated.
Maybe I'll be back to the track in two weeks!
I'll take it a lot easier on the nitrous until I figure out the problem with detonation or whatever is melting spark slugs. Something still weird going on there.
yeah, that doesn't surprise me... those valves are pretty tough stuff, so if you burn one up or break off a piece of one, it's going to do some damage to at minimum the valve seat and probably the cylinder walls and/or the top of the piston.
usually there's more damage than just the toasted valve.
Maybe I missed it but what makes you think you melted a valve? Just because you melted spark plugs? I've melted plus before and not hurt the valves (blew the HG and cracked ring lands though).
An engine swap is imho more cost effective and easier than pulling the heads. It's alot of work to pull the heads on a VQ, engine swap on the other hand is pretty straightforward, as long as you have the proper tools at your disposal (air tools and a hoist, a couple floor jacks).
My observations with a Sears threaded compression checker:
NO compression in #4 cylinder - visual inspection through the sparkplug hole shows the top of the piston is intact, (but the plug was wet w/gasoline) after driving 90+ miles back from the strip in Kansas City, no oil was lost, blown out, or dripped away.
No coolant was lost or showed in the three front cylinders. Adjacent cylinders had 190-200 readings. Am I missing something? Is there something else I can test or measure????? And, what the heck is going on inside when this happens? Is this detonation, very high cylinder pressures from using nitrous, or World War III inside there?
Unloaded the replacment engine at the shop tonight, and that is a small motor to be pushing a 3000-lb car so fast and hard in the 1/4!
Any insights would be appreciated.......
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
