1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
99se 5sp vs. 92 5.0 mustang5sp
Old Jan 19, 2006 | 07:30 AM
blackbeautyse97
Hey guys my buddy is wanting to race my 99se 5sp .....I have a y pipe stock intake for torque and jwt ecu....he has a 92 mustang gt. 5.0 5sp KaN intake he wants to race for $150.... when i had my auto ypipe intake and sp2 i ran about 21/2 cars do you think i could beat him in my 5sp
Old Jan 19, 2006 | 07:32 AM
JClaw's Avatar
If you had a VI I would've said go for it, but given that you have the stock intake manifold I'd give a slight edge to the 5.0.
Old Jan 19, 2006 | 07:48 AM
NmexMAX's Avatar
dot dot dot ...
Is this a street race or at the track?
Stop being and just race.. The outcome depends on wayyy too many things.
Only race for $$$ if you're confident you can win, especially for your fisrt born, errr I mean 150$.
Post timeslips when you're done.
Old Jan 19, 2006 | 01:03 PM
Hoooper
dont do it, you wont run a low 14, that 5 liter has the ability to run low 14s.
Old Jan 19, 2006 | 02:18 PM
Mass_Media's Avatar
Mass_Media™
Jus because a car has an ability doesn't mean it will.
Id say go for it. Never hurts to try
Old Jan 19, 2006 | 02:34 PM
icedout's Avatar
i would say you can take him..he just has a k&n filter thoes car arent crazy fast.Just race him this way you can make 150$
Old Jan 19, 2006 | 07:31 PM
Ninos_Maxima's Avatar
be the change u want2C
hopefully hell panic and stay stuck at start makin smoke... thats if he is a bad driver... it would be close anyhow... dont underestimate those cars... but then again sounds like your a nooB too..
Old Jan 19, 2006 | 07:40 PM
JClaw's Avatar
I have a feeling someone is gonna lose 150 bucks...
Old Jan 20, 2006 | 12:13 AM
Nealoc187's Avatar
SLOW
It's possible that you would win, but I think the likelyhood is that you'll get smacked. Bet him a 6 pack instead (and then drink it after you've done all your driving for the night of course).
Old Jan 20, 2006 | 06:04 AM
JClaw's Avatar
Yeah don't drink and drive, you could spill it
Old Jan 20, 2006 | 07:17 AM
C MAX's Avatar
unless he messes up on his launch he's gonna give it to you, those things are known for there quick pick up even stock
Old Jan 20, 2006 | 03:13 PM
GBAUER's Avatar
He'll beat you. He might beat my 2k3 even (it's not stock).
Old Jan 20, 2006 | 04:45 PM
Hoooper
if you want to lose 150, just give it to me so i can put stuff on my car and beat him. unless he smoked the tires for a little and you get a perfect launch, youll be checkin for dirt spots on his bumper.
Old Jan 20, 2006 | 07:58 PM
drvefastho's Avatar
hmm
ok a stock 92 GT will run high 14's to low 15's with a good driver...an LX (which is one with a bunch of plastic side cladding)..or the one u can see the exhaust pipes on the back....they can easily run mid 14's ....with a good driver too..... and ur car...well....i think the cars might be about the same
unless he has changed the rear end of the car.....u change the gears and he'll hand ur *** to u...... u can easily run 13's swapping out the rear end on a fox 5.0...so its not just the engine. if ur not family with a stock 5.0 engine then he could have stuff u wouldnt know about...a simple advancing of the ignition timing (which is a very common mod)...or a Fuel pressure regulator(another common one)....these two mods together could give the v8 gains ud see by a y pipe .....
your best bet is to run him for a 6 pack like someone else mentioned.....if u run and lose....ull lose to a mustang and lose 150 bucks.....thats gay
anywho...im not saying Dont race him.....just dont do it for 150!...the fact that ur thinking ull lose will probably make u nervous and ull end up losing..hehe
<---had an 89 5.0gt....
Old Jan 22, 2006 | 10:08 PM
Cliff Clavin's Avatar
Way out West
Have you run your car at the track?
I would probably compare 1/4 times with him before racing.
Like drvefastho said, there are a lot of things you can do to a Mustang to eat up people in the 1/4 mile. Rearend would be the biggest. Usually exhaust work helps those out, too.
Remember, a 92 Mustang GT stock has 225 hp, 300 ft lbs of torque and weighs about the same as a Maxima, just a little over 3k lbs. Stock 1/4 miles times (magazine tests) for the 86-93 stangs are usually around 14.5-14.9 with a 5-speed.
I had an 86 GT convertible (first year of FI, 200 hp, 285 ft lb of torque -- crappiest year for FI GTs) and with a k &n panel filter, an off-road x-pipe and better exhaust, it was at least as quick as my max, which runs in the high 14s. My old Mustang was a convertible, too, which is heavier.
Old Jan 23, 2006 | 08:52 PM
Aaron92SE's Avatar
NWP Engineering.com
I'd say the 5.0 will win with a 14.7 with street tires and good driver. A good time for you will be 14.9. I would definitely put my money on the Stang if he's capable of launching that thing. Race him and tell us how it went. I want to see timeslips also!
Old Jan 24, 2006 | 04:17 PM
howitzer's Avatar
that race is up in the air, i work on a lot of 5ltrs and big up to the comment on rear end swaps, they are key with those cars , stock rear gears are pathetic 2.73s
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
Random
Nov 26, 2000 01:25 PM
emax02
Nov 8, 2000 09:52 AM
