1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Something's wrong with my car.
Old Apr 22, 2006 | 07:47 AM
tavarish's Avatar
fwd gone rwd cr00
Hey, it was my first time at the track, and the best I could do was a 15.1 at 91.51 mph. I also could not get past a 2.3xx 60'. My clutch was slipping, but i thought i could at least get into the 14's. i have a 1998 GLE fully loaded, converted to 5spd, y-pipe, no spare tire, no jack, ADR 17", 17lbs each, (did have a wooden board in the trunk, but i doubt that made any diff), on a slipping ACT stage 1 clutch. I took out my subs for the track run.
A friend from the .org showed up for his first time at the track as well, and his FIRST RUN was a 14.8 with a 2.3 60', and a slipping clutch.
Before my car went to the track, it started making a weird ticking noise.
I'm gonna track my car again, but I hope to get into the 14's. what do you reccommend, as far as mods, weight reduction? I'm only keeping the VQ30 for about one more month until i do the 3.5 swap.
Thanks,
-Freddy
Old Apr 22, 2006 | 08:29 AM
Nealoc187's Avatar
SLOW
How bad is the clutch slipping? That is the most important question. If it's slipping significantly then your run was botched from the beginning so your 1/4 mile doesn't necessesarily indicate a problem (besides the slipping clutch).
Old Apr 22, 2006 | 08:43 AM
tavarish's Avatar
fwd gone rwd cr00
I didn't chirp any gear, and it was slipping pretty considerably.
I verified this, and it WASNT an ACT Stage 1, it was a Daikin OEM replacement clutch. (Key Value)
Old Apr 22, 2006 | 11:53 PM
Zack342's Avatar
Thanks,
-Freddy
Your trap seems a tad low. I think your trap does confirm your time. what did your friend trap when he ran 14.8?
Old Apr 23, 2006 | 12:22 AM
tedo007's Avatar
faster than you think
did you lets your car cool down befor you ran it. you got catback? get catback you might see some better result with it
Old Apr 23, 2006 | 02:24 PM
liqidvenom's Avatar
brotherhood of tq
i got a 94.?mph trap when i ran the 14.8, but i think that the track was very cold and that hurt the people that were on street tires...ill post up my slips later if anyone cares. ohh i also had a 2.3?? 60' on that first pass.
Old Apr 23, 2006 | 05:11 PM
tavarish's Avatar
fwd gone rwd cr00
no catback, stock exhaust with bad exhaust leak.
Old Apr 23, 2006 | 05:12 PM
tavarish's Avatar
fwd gone rwd cr00
i'm gonna run on my stock sawblades when i go again, and i'm taking out my backseat, and passenger's seat.
Old Apr 23, 2006 | 07:34 PM
MaxFanatik's Avatar
fred, i think its the slipping clutch, maybe the fac tu dont hvae more airry exhaust flow can be kickin u back a bit GL next time
MaxFanatik's Avatar
Old Apr 24, 2006 | 08:37 PM
MaximA StyLeZ's Avatar
I also ran at EnglishTown, I ran a 14.75 @92.3 w/ a 2.37 60'. Don't you guys think my trap is low as well ? How could I run I think a good time with such a crappy 60' and trap? MODs: Y-pipe/Short Ram/Cat-back Sawblades.
Old Apr 24, 2006 | 10:17 PM
liqidvenom's Avatar
brotherhood of tq
not sure..u must have managed to leave the line and pull hard then maybe slow up a bit.
Old Apr 25, 2006 | 08:30 AM
tavarish's Avatar
fwd gone rwd cr00
f'ucking factory freaks, is what it is.
Old Apr 25, 2006 | 09:10 AM
C MAX's Avatar
tavarish is this your first run on the track, if so there are many factors that make your time. if you have run before and more than once then what were those numbers before if any? 15.1 isnt that bad considering a better take off could yield you a 14.9 which aint bad at all. i ran a 14.6 once and turned around and ran a 13.1 right behind it all because my first launch was horrible, but my mph remained the same 103-106mph. 92mph is just about right for your poer output. a 96 trap and up would put you in the 230hp range.
Old Apr 25, 2006 | 11:17 AM
SDot82's Avatar
I must suck because all I could manage was 14.6 @ 98 in the 1/4 (that was without the nitrous only 00VI, intake, and y-pipe).
Old Apr 25, 2006 | 01:01 PM
C MAX's Avatar
humn that trap sounds like a 60 shot, you sure thats without nitrous. what is your n/a hp.
Old Apr 25, 2006 | 01:52 PM
liqidvenom's Avatar
brotherhood of tq
98mph is a great trap for a 4th gen....wat was ur launch strategy and u have a slip to post
Old Apr 25, 2006 | 03:50 PM
tavarish's Avatar
fwd gone rwd cr00
yea, it was my first run at the track. I guess i gotta get me some more mods (read: DECENT , non-TICKING ENGINE) so I can get a better slip next time I go. I know with 200whp, you can get into the 13's with a good driver.
Old Apr 25, 2006 | 05:31 PM
SDot82's Avatar
That was right before I got the nitrous its all VI , n/a is 173hp 190tq but the afr was below 10. I have a VAFC program tuned for 13.2 but took it out for this dyno to see what my afr would be without it (for the nitrous later). So plan and simple I don't know what my hp is with my VAFC program.
Old Apr 25, 2006 | 05:32 PM
Zack342's Avatar
orly......200whp you say
Old Apr 25, 2006 | 05:47 PM
SDot82's Avatar
Well this is the only one I could find its almost 98 if you round up ...
Old Apr 25, 2006 | 06:08 PM
C MAX's Avatar
if thats all motor you got a good amount of power there, you maintained maximum power thru the last 1/8th. either way pretty decent numbers
Old Apr 25, 2006 | 06:49 PM
t6378tp's Avatar
Turbo 3.5
I went this past friday and ran
60ft 2.374
330 6.622
1/8 10.093
1/4 15.713
mph 84.89
I think somethings wrong, I ran a 16.373 at 83mph 2 runs before with a 2.598 60ft
Old Apr 26, 2006 | 12:05 PM
tavarish's Avatar
fwd gone rwd cr00
krismax ran a 13.8 with similar mods to yours.
Old Apr 26, 2006 | 12:06 PM
tavarish's Avatar
fwd gone rwd cr00
60ft 2.374
330 6.622
1/8 10.093
1/4 15.713
mph 84.89
if you're auto that's fine. Get a better 60' (easier said than done), and you'll see a better slip. Trap is a bit slow though.
Old Apr 28, 2006 | 12:58 AM
tedo007's Avatar
60ft 2.374
330 6.622
1/8 10.093
1/4 15.713
mph 84.89
that shows that you need more practice you said you ran before with 2.598 60 ft and you got lil bit better and ran 2.3 60ft. get that 60ft in 2.2 you be in 9's in 1/8 mile and you'll get around 15.5 in 1/4 mile
Old Apr 28, 2006 | 11:26 AM
pod97654's Avatar
Wow, what a timeslip. this is hard to understand. i am curently run a consistant 14.75 at 93.9mph, with a 2.3 60'. how can we have a similar 60' similar 1/4 and you end at 98mph? did you miss a gear? The only mods i curently have is a stillen y-pipe and a short ram intake. And h*ll i think if i get my launch perfect i could see 14.5.
Old Apr 28, 2006 | 11:42 AM
jmeister's Avatar
Was that with his no rev limiter & serious weight reduction?
Old Apr 28, 2006 | 12:23 PM
liqidvenom's Avatar
brotherhood of tq
he also gutted his car and had a pathy tb if i recall
Old Apr 28, 2006 | 05:35 PM
tavarish's Avatar
fwd gone rwd cr00
rev limit at 8k, and some weight reduction, but nothing seriously bad, i've been in his car, it had a full interior.
He also had a 00vi, and i doubt it makes any useable power at 8k rpms, so the rev limit that far up would be pretty much negligiblie, and valve float would be an issue.
tavarish's Avatar
fwd gone rwd cr00
will you do NOT have the dirtiest 4th gen in jersey.
Old Apr 28, 2006 | 05:44 PM
liqidvenom's Avatar
brotherhood of tq
i dont think that valve float would be that big of an issue and the 00vi makes probally worlds more power at 8k then the usim
D Mason
Jun 21, 2016 04:43 AM
Forge277
Jun 13, 2016 09:26 PM
REDinLV
Sep 28, 2015 12:31 AM
