1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Quickets and Fastest N/A Maxima is an automatic. (finally)
Old Jun 13, 2006 | 04:31 PM
  #41
Jime's Avatar
Originally Posted by Aaron92SE
That is awesome! I'm interested in your results with the bigger MAF.
Also, with your TC, do you actually see 3400 on the tach when you launch it off idle? Also, can you stall it up that high while holding the car still with the brakes?
I have a Edge Racing TC also and he got me about 2900 brake and flash stall with what I can see on my tach. My stock brake stall was 1800.
The 3.5 MAF is now on and I can't say that I can tell any difference but seat of the pants isn't the best way to compare and I am going to start doing some real comparisons using timed runs etc because I can switch them in less than 2 mins.
Yes I see almost 3400, hard to tell because it goes up so fast off idle. Can I stall it that high while holding the car still with the brakes? Absolutely not, I even put new rotors, pads, SS brake lines etc and they will not hold past 2500 and definately not at WOT which dissapoints me for launching. Now I need to get the 2-step working so I can launch consistently with the line-loc.
Old Jun 15, 2006 | 11:27 AM
  #42
Aaron92SE's Avatar
NWP Engineering.com
Oh ok. When you get some timed comparison runs, please let us know about the MAF.
My stall is about 2900 and I am able to hold my car perfectly still and have my throttle all the way open! But just BARELY. I have to ease on the gas slowly and STAND on the brakes and it will barely hold the car still at 2900rpm. I just did that to measure it. I don't launch that way. I seem to bog a little and my 60 foot suffers by a couple hundreds with the slicks. I still need to play with my launch a little better to see if I can shave some more time from it.
Thanks.
schmellyfart
Sep 25, 2015 04:47 PM
tcb_02_max
Sep 11, 2015 12:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Max8
Aug 15, 2015 07:06 AM
