1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Need Slicks Help
Old Jul 28, 2006 | 05:24 AM
Hump-Free's Avatar
Need Slicks Help
Ok guys I have a 87 maxima and it is boosted with a VG33 in it at 13psi. I have a set of 20" x 8" on a 14" rim. Those came with the car. I think those are too small of a slick for it. Other People have told me that too.
What are my other options on this. Like what size is best to run on. I have a set of 15" rims for it.
I have not ran it yet at the track with the 20" Slick but the owner said before I bought it that he was crossing the line in the 4500RPM range in 5th gear.
Old Jul 28, 2006 | 04:55 PM
Nealoc187's Avatar
SLOW
20" slicks lol I didn't even know they made them that small. You probably don't want to be running 5th gear through the traps. 24.5 or 26" slick would probably work out better, but I'd need more info to really make a good assessment. If you have a dyno plot, dyno numbers, timeslip, etc that would really help. I need to get some idea of what kind of power you are putting down, and what your gearing is like.
Old Jul 29, 2006 | 06:13 AM
Hump-Free's Avatar
I put down 393FTQ and 287WHP. Times on street tires are about a 13.8 on average with trap speeds of 108. I am not at my house right now to give exact times but I will post up when I get back. So a 20" slick is for sure too small. My next step is 24.5" slick.
Where is the best place to buy them.
Old Jul 29, 2006 | 12:43 PM
Nealoc187's Avatar
SLOW
It's good that you've got some numbers, that will help me run the simulations. What RPM was your HP and TQ number at, if you have the dyno sheet, that would be even better - and post up that timeslip when you're able. I'm assuming your car is a 5spd using the stock gear ratios for an 87 maxima, right?
Old Jul 29, 2006 | 01:13 PM
Nealoc187's Avatar
SLOW
Here's what I've got so far, assuming your HP and TQ peaks about where the stock numbers peak. If your car peaks differently then that could totally change these numbers. This was basically just a gearing test - I wouldn't pay much attention to the 60' times, etc. I was just running this test to see where in the powerband your car would be, given different slick sizes.
Tire Dia. 1/4ET Trap 60 ft notes
20" 5.23 12.62 111.6 1.78 cross line @ 4600rpm in 5th - blah
22" 5.76 12.55 110.9 1.81 shift to 5th right before line - bad
23" 6.02 12.44 113.1 1.82 shift to 5th right at or after line - careful
24.5" 6.41 12.43 112.8 1.85 shift to 5th @ 121mph - plenty of headroom
26" 6.81 12.45 112.3 1.90 shift to 4th @ 100, 5th @ 129
27" 7.07 12.45 112.0 1.92 shift to 4th @ 104, 5th @ 134
28" 7.33 12.47 111.7 1.95 shift to 4th @ 108, to 5th @ 139
Old Jul 31, 2006 | 12:10 AM
04silverse's Avatar
hump i would go with what i'm gonna run on my 04 26x10.50 mickey thompson et streets they hook awesome at bristol!
Old Jul 31, 2006 | 06:04 AM
Hump-Free's Avatar
Where did you get yours at? I need to order some. I dont know If i will go with 26's or not. What size tire does 24.5" and 26" slicks compair to? My car has been lowered about 1.75 inches.
Old Jul 31, 2006 | 02:28 PM
Nealoc187's Avatar
SLOW
do you have the timeslip or dyno plot available so i can do a better test?
Old Jul 31, 2006 | 06:18 PM
04silverse's Avatar
i ordered mine from summit i bought the radials tho which are sized 275/40-17
but the 26/10.50-15 should equal a 275/50-15
Old Aug 1, 2006 | 08:46 PM
Hump-Free's Avatar
I have a dyno sheet but it is not real high numbers. I cant find the good Dyno sheet or slips. I will look again.
Old Aug 2, 2006 | 02:25 PM
JClaw's Avatar
I would not go with anything smaller than 24.5's at your power level.
Old Aug 2, 2006 | 07:23 PM
Hump-Free's Avatar
Guys, I decided to sell it or part it out. Nah just ****ing with you all. I am wanting to build one of the world fastest maxima's. I am gonna reroute my turbo to sit over my tranny and build my extra motor i have with piston and rods. I am looking to hit low 11's on Turbo no Spray.
So a 26" would do great?
Maxima_Joe
Nov 25, 2015 08:19 AM
Xi MaX SC
Aug 7, 2015 08:47 AM
MardiGrasMax
Dec 3, 2001 07:27 PM
