1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Mickey Thompson vs M&H Racemaster Slicks Automatic Trans
Old Oct 3, 2006 | 05:56 AM
Jime's Avatar
Last week I purchased my first set of M&H slicks, MHR-21 7.5/23-15.
Previously I have used M/T 3019 22.0/8.0-15 (8 pair) and M/T 3015 24.5/8.0-15. (1 Pair) Average is 125 runs per set.
My best 60' times have always been above 1.9 with the M/T 22's and above 2.0 with the 24.5's. Also the consistency has not been where I woud like to see it ie 1.93-2.20 under same conditions, pressure etc.
With the M&H's I did a total of 16 runs from fri night till sun aft. Runs varied between 1.89 and 1.94 which is only 0.05 vs 0.27 from the M/T's.
Also I could feel the difference off the line, there was a definitive jerk upon launch that wasn't there with the M/T's. Obviously I am sticking with the M&H's considering the above, I was staying away because I figured the 1" taller tire would slow it down like the 24.5's did, they increased my 1/4 times by .3 seconds compared to the 22's. Also the 7.5/23 M&H's require only a 6" rim vs 8" from the M/T's. I have mounted them on 7's and they are perfectly flat across the tread inflated. Pressure was set a 17 and there was no spinning or squeak on launch so it was left there.
Anyway just my $.02, take it for what its worth.
Old Oct 3, 2006 | 07:01 AM
Nealoc187's Avatar
SLOW
Finally someone else that has realized that M&Hs hook better than MTs M&Hs rock my socks.
Old Oct 3, 2006 | 07:17 AM
DandyMax's Avatar
3.5 in the works
Thanks Jim. For the most part I am happy with my M&H's too.
My 60 fts under normal circumstances vary only 3-4 hundredths, usually in the 1.75 to 1.79 area, depending on prep etc and that's with a stick shift, so it makes sense with auto you could be that consistent too...
Old Oct 3, 2006 | 08:29 AM
JClaw's Avatar
Pulled a whole bunch of runs in the 1.75-1.85 range on the very first day I ever ran slicks on any car whatover so they rock
A car with more power could do VERY good on 24.5's or 26's M&H's mounted on the correct 8-inch wide rim. They are notoriously sticker than the MT's, and be sure to burn the crap out of them.
Old Oct 3, 2006 | 08:59 PM
krismax's Avatar
Father of the 00 VI
right here another M&H lover i run 24.5 -8.0 -15
Old Oct 4, 2006 | 02:57 AM
96sleeper's Avatar
Do they make that size? I think I remember seeing 24.5x8.5-15 in M&H, but the only 24.5x8.0-15 I could find is M/T.
Old Oct 4, 2006 | 06:29 AM
grey99max's Avatar
LandShark has Cosworth
That goes for me, too..... I use the 23/8.5/15 M&H on 8" alloy wheels..
This is from the last visit to KCIR. I was having nitrous feed problems, but still very consistent 60' - just not world-class times.. They do snap your head back.
60'.......1.986......2.033.......1.994.......2.059
1/4......13.463.....13.508.....13.432.....13.628
Old Oct 4, 2006 | 11:23 AM
streetzlegend's Avatar
omg. GREAT! about 15seconds ago i just received thru fedex my 22x8x15 MT and i come to the forum and i see this!!!! =( oh well ill go with MH next time. Got them used, however I do not know if they are a little too used since iv never seen slicks inperson. I payed $215 Shipped, was told that they only had about 6 to 8 passes on them. I dont know if i got ripped off
heres a few pics of the wear indicators.
http://uploader.ws/upload/200610/DSC00458.jpg
http://uploader.ws/upload/200610/DSC00456.jpg
http://uploader.ws/upload/200610/DSC00455.jpg
http://uploader.ws/upload/200610/DSC00454.jpg
Old Oct 4, 2006 | 12:28 PM
grey99max's Avatar
I think you'll have a chance to buy M&H sooner than you realize...... The wear-indicator pits look kinda shallow.
My size of M&H, new, were about $310/pair plus shipping. Jegs or Summitt, I forget.
Suck it in, you've got enough tread for a few track days there. Enjoy the slicks - you're gonna be surprised. Burn those down to the cords, then you'll be ready for something new.
Old Oct 5, 2006 | 05:21 AM
Jime's Avatar
M/T's aren't junk, I have done many 1.7 60's with them and they are the only tire I have used for the last 4 years. The only reason I tried the M&H's was their 23x7.5x15 only requires a 6" rim vs an 8" for the smallest 15" M/T. I have always had a problem with the outside of the tire wearing out way before the centre and I think its caused by having too narrow a rim.
Old Oct 5, 2006 | 10:53 AM
k cool. im going to see how i do and finally spray from the line (never done it not even on street tires) and see if they hold up =) not going to do a burn out at first to see how they do n then go from there. hopefully I can bring that 2.3 to at least a 2.0 or something (75shot).
btw im going to be mounting them on the sawblades. so i might have problem like u did with the sides wearing quicker.
Old Oct 7, 2006 | 09:03 AM
i just got my MT mounted on the sawblades. They are at 30 psi. should I empty them when storing them and not in use? or i can just leave it at 30?
Old Oct 7, 2006 | 12:22 PM
96sleeper's Avatar
if you didn't use tubes they will empty themselves.
Old Oct 7, 2006 | 04:34 PM
krismax's Avatar
Father of the 00 VI
sorry made a mistake it is 8.5
Old Oct 7, 2006 | 05:06 PM
Tubes? what is this in which you speak off?
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
