1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Initial testing of quick release solid axle
Old Oct 7, 2006 | 07:03 PM
JClaw's Avatar
Got an early prototype built and we got to test it tonight at the track. This first prototype is nowhere near a beefy as I want it but this was principle testing (of something I've long wanted to test to increase FWD traction).
We first did some testing on the street and the main thing I noticed is that although it did reduce wheelspin somewhat, both tires really seemed to want to act together. When they break loose, it's an even, controlled, united wheelspin.
The car was acting wierd just like it was last year when my trap speed went back and forth between 98-99 mph to 103-105 mph. Something about the timing. The top end just wasn't there.
Anywho, this car's previous best 60 foot on stock tires with the 3.0L was 2.26.
Tonight I pulled a 2.070 60 foot (on a 14.92 run, go figure) with a 4000 rpm quick slip on stock 215/60/15 tires. The car hooked and went. I'm pretty sure a 2.07 is unheard of for a Y/E 5-speed. Everything except the exhaust system is stock. Suspension (original 130k miles), bushings (same here), funny alignement, etc. I wanted slicks badly tonight but the stock clutch would've said no thanks.
This "solid axle" is a solid link between both control arms and prevents control arm deflection, wheelhop and weight transfer all at the same time.
So far its street driven matters are suprisingly good and predictable. But that is because it's nowhere near as stiff as I want it yet. Basically acts as a stiff as hell swaybar. I'm gonna replace the 1-inch square with a beefy 2" tube and make this mod a 'track only' (hence the "quick release" part). Stay tuned.
Old Oct 7, 2006 | 07:47 PM
Tatanko's Avatar
Bacon Lover
Wow, very interesting. I'd be interested in this if you'd be willing to make some and they weren't overly expensive. Not at the moment, since I have no cash and am currently dead in the middle of my 00VI swap, but soon enough.
Thank you for yet again being a pioneer
Old Oct 7, 2006 | 07:54 PM
JClaw's Avatar
Well if my 240 ever gets started we plan on spending the next 3 weeks or so intensely on drag racing before the season ends.
Old Oct 7, 2006 | 07:59 PM
Tatanko's Avatar
Bacon Lover
Good stuff. Perfect opportunity to test it out and perfect it.
Old Oct 7, 2006 | 08:04 PM
JClaw's Avatar
I want to know what my 240 traps and at which RPM it ends the 1/4 mile in 5th gear before the winter so I can re-gear it accordingly. I missed this season but I want to be ready early next spring not to miss anything like this year or '05.
I also want to do all the testing on the maxima before the tracks close early November.
Old Oct 7, 2006 | 08:40 PM
96blkonblkse's Avatar
wow 2.07 60ft on stock street tires is crazy. are you going to be selling the verison that you currently have on the car, the 1" square version?
Old Oct 7, 2006 | 09:41 PM
Nealoc187's Avatar
SLOW
interesting. post a pic of it.
Old Oct 7, 2006 | 09:59 PM
JClaw's Avatar
Nope. Too wimpy. I'm out to prove that it's possible to pull a 1.9xx on average street tires in a maxima.
I will once I get the second version (beefy tubular one) done and tested. Give me some time to come up with something hardcore enough - it might put you in the 11's.
Old Oct 8, 2006 | 08:04 AM
grey99max's Avatar
LandShark has Cosworth
Sounds like you've done it again. Sign me up for one if you decide to build them. Otherwise, pictures please. This is really exciting !!
Will this one be called "Jbar-II" ????
Old Oct 8, 2006 | 07:35 PM
Fr33way™'s Avatar
Wild for Width
Very interested in this. Keep us updated!
PH98I30
29
Feb 10, 2025 12:03 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
