1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
why? extremely mad after gainsville
Old Nov 12, 2006 | 06:52 AM
maximaownsyou's Avatar
ok i have a 2002 with the 3.5 and i ran extremely bad...
60' ... 2.619
330 ... 6.907
1/8 ... 10.318
MPH ... 73.05
1000 ... 13.241
1/4 ... 15.714
MPH ... 91.10
any ideas? was only going hoping for 14's, especially since the true stock
numbers sticky says this car should be mid 14's stock and low 14's with a mod
or two? i have no idea what happened but any ideas are appreciated... i ran
4 times and this was my best run... i know.. pitiful
Old Nov 12, 2006 | 07:27 AM
Kevlo911's Avatar
Kevlo for President
Auto? Manual?
Bad engine?
Old Nov 12, 2006 | 07:40 AM
its auto but still, no engine seems fine... no hesistation, no misfiring, seems real peppy (if i give it much gas at all off the line the tires spin)
Old Nov 12, 2006 | 08:07 AM
SonicDust187's Avatar
Wow dude, you were spining tires like crazy on launch. Drop that 60' to 2.1-2.2 and you are in high 14s.
Old Nov 12, 2006 | 08:18 AM
Nismo3112's Avatar
Custom User Title
Go easier on the launch.. and you should be in the 14's.
Old Nov 12, 2006 | 01:10 PM
Hoooper
the speed seems pretty low for spinning the tires though, i dunno. try warming the tires in the waterbox before your run even if youre on street tires, looks like you could use all the help you can get. dont expect much better than 14.8 next time you go, it took me a couple runs before i got into the 14's with my 2k2 auto. you just need to figure out the best launch.
Old Nov 12, 2006 | 02:05 PM
Nismo87SE's Avatar
I looked up the weather conditions yesterday at your track and the DA' was around 600ft. So conditions wouldn't have caused the car to run so slow. It seems to me that your launch was pretty bad, normal 60' times should be 2.2x range. Another thing to consider is shift points and engine temp? Did you allow the engine to cool between runs or did you hot lap, also did you shift or did the car do the shifting? I'm thinking with a better launch 2.2x and different shift points it should run 14.7-14.9s @ 91-93mph.
60' ... 2.619
330 ... 6.907
1/8 ... 10.318
MPH ... 73.05
1000 ... 13.241
1/4 ... 15.714
MPH ... 91.10
Old Nov 12, 2006 | 02:21 PM
gblkrt09
ya its your 60, get that down and u should be alright, isn't it the manual 5.5's that are in the mid 14's stock
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
AboveDaCloudz
Oct 8, 2015 11:25 PM
aackshun
Sep 20, 2015 10:20 PM
