1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
How to get a 4th gen auto to run 13's
Old Nov 15, 2006 | 06:14 PM
t6378tp's Avatar
Turbo 3.5
All opinions welcome, What will it take to get a 4th gen auto in good shape to run mid to high 13's this is my guess
1. 75shot of nitrous
2. remove the passanger and back seat, spare and jack
3. 1 step colder plugs
4. y-pipe
5. alteast a K/N drop-in filter
6. good tires on light weight rims up front
7. drop mod
8. bottle warmer
Old Nov 15, 2006 | 06:31 PM
grey99max's Avatar
LandShark has Cosworth
4. y-pipe
7. drop mod
Read my mods in my sig ??? They work for me......
Actually, your list is a good place to start. Use a tank heater, get GOOD tires, preferably DRs, put Mobil1 in the tranny and engine, and get LOTS of practice w/burnouts and launching your car. You may need tractions bars.
The first 60' is critical - the 330' is very important and depends mostly on your driving ability. After the first 1/8 mile, it's just engine power - and steering in a straight line....
Old Nov 15, 2006 | 06:41 PM
t6378tp's Avatar
Turbo 3.5
I'll add the bottle warmer to the list, but mobil1 what is that for. I am guessing peace of mind
Old Nov 15, 2006 | 07:03 PM
ajcool2's Avatar
All that sounds about right.
Old Nov 15, 2006 | 07:08 PM
grey99max's Avatar
Mobil1 and a tranny cooler keeps your tranny in one piece - and gives you peace of mind......
Old Nov 15, 2006 | 08:27 PM
streetzlegend's Avatar
^w/e he said..
slicks with 75shot+ypipe alone should get you in 13's, now if u wanna keep the car from dying. then 2 step colder, drop resistor (A MUST!!!), mobil 1, SLICKS. screw dr's get full slicks. cuz later ur goign to be complaining that ur spinnin the DR's off the line.
Old Nov 16, 2006 | 01:49 PM
Hoooper
3.5 swap . its been proven to get you into the 12's with the right tuning
Old Nov 16, 2006 | 02:16 PM
JClaw's Avatar
Yep. And don't skimp on the tires.
Old Nov 16, 2006 | 03:00 PM
t6378tp's Avatar
Turbo 3.5
yeah but if you take everything from the list above it totals alittle less than 1000.00 bucks and a 3.5 swap is what 700-1000 for just the motor alone, no point in snatching out a good motor wait till is goes bad.
And remember everything listed above can be swaped over if a 3.5 job is done later
Old Nov 16, 2006 | 03:11 PM
Hoooper
its all the same. if he does the 3.5swap now the stuff above can be added later just like it could be moved over if done first. it doesnt matter, its all preference. 3.5 swap will always be fast, nitrous is only fast when spraying
Old Nov 16, 2006 | 03:55 PM
t6378tp's Avatar
Turbo 3.5
true, your right I would rather do the swap when my motor dies. plus if funds are tight you can buy a piece here a piece there
Old Nov 17, 2006 | 08:41 PM
ghostmax301's Avatar
What are the affects of running colder plugs on a N/A motor.
Cons and Pros and should i go 1 step or 2 steps colder?
Old Nov 17, 2006 | 10:05 PM
Nealoc187's Avatar
SLOW
Two steps colder is totally pointless for that power level , and honestly I don't think you'd need 1 step colder for a 75 shot. You'd be fine on a stock plug imho.
Old Nov 18, 2006 | 05:14 AM
t6378tp's Avatar
Turbo 3.5
are you running nitrous, and if so what plugs. I was thinking 1 step colder in the summer and stock copper plugs for the winter
Old Nov 18, 2006 | 08:12 AM
Nealoc187's Avatar
SLOW
No my car is turbocharged. I use BKR6Es.
Old Nov 18, 2006 | 09:55 AM
SonicDust187's Avatar
I don't agree with this. When I used to have nitrous I would run one step colder setup upto 75 shot with 0.036 gap. Then I switched to one step colder and stock gap with 100 shot and blew my maf, filter and intake manifold gasket from the backfire. I would say 2 step is a must with a 0.036 gap.
Old Nov 18, 2006 | 10:16 AM
t6378tp's Avatar
Turbo 3.5
I not sure but I think the backfire is caused by the nitrous ingniting in the intake manifold and I know on high shot of nitrous you have to close the gap on your plugs cause the cyinder pressure increase from the nitrous and can blow out the spark but even if that happened wouldn't that just make you shoot ducks out the exhuast
Now correct me if I am wrong, plus I think he was only trying to say it is a option not a must to run 2 step colder
Old Nov 18, 2006 | 10:24 AM
Why take the chance. I would run 2 step colder with high nitrous shots.
Old Nov 18, 2006 | 11:31 AM
Nealoc187's Avatar
SLOW
Nitrous backfires aren't a result of plug selection. Plug selection is a preignition/detonation issue.
t6378tp's Avatar
Turbo 3.5
I agree if it gives you peace of mind, I would do the same if I had a nitrous backfire like that but I do not think it would solve your problem
Oh and let me guess you were running a wet setup when it happened
Old Nov 18, 2006 | 11:32 AM
t6378tp's Avatar
Turbo 3.5
thats what I was thinking just was not 100%
Old Nov 18, 2006 | 04:03 PM
grey99max's Avatar
And if you want to be safe with a stock ECU - even at 150-shot levels - use copper plugs two steps colder, shave the grounds back to a stub for side-gapping, and use VP Street Blaze 103 (red) or Sunoco GT 104 octane gas (blue).
You should side-gap at .030 w/higher (100+) shot levels, unless you use a voltage booster set to 16 volts (for $50), then you can gap at .035 for better top-end pull.
Been there, learned all that. Once you get the fundamentals in place, you can raise the shot level to whatever you're brave enough to try, and your engine will probably survive........
Old Nov 18, 2006 | 07:45 PM
t6378tp's Avatar
Turbo 3.5
(grey99max)
I like the voltage booster idea, I read a few of your posts when you talked about it I am currently looking for more info about. would you be able to direct me to some links
Old Nov 18, 2006 | 08:50 PM
So what if it was wet. I know a lot of people with wet kits running 100 shot setups on maximas.
Old Nov 18, 2006 | 09:00 PM
grey99max's Avatar
(grey99max)
http://www.powerstream.com/dcdc.htm
I'm using the 11-15volt input 90 watt converter. Works good....
Old Nov 19, 2006 | 08:27 PM
t6378tp's Avatar
Turbo 3.5
thanks alots
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
WeetoddA32
Aug 16, 2015 12:45 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
