1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
How is this possible
Old May 18, 2007 | 04:11 PM
Merlyn's Avatar
And... I'm out
So I took my maxima to the track a few weeks ago and ran a 14.290 at 101 MPH
everyone was like that is a trap speed of a 13's car so I went back today
I weight 3520 BOTH Visits
Only difference in the car is new motor mounts
This is my first 14.290 Second
Temp - 83F
R/T - 1.1011
60' - 2.273
330 - 6.146
1/8 - 9.325
MPH - 79.16
1000 - 12.029
1/4 - 14.290
MPH - 101.32
This is todays run
Temp - 78F
R/T - .606
60' - 2.220
330 - 6.121
1/8 - 9.299
MPH - 78.97
1000 - 12.014
1/4 - 14.290
MPH - 99.88
Can someone explain to me how...
A car weighing the same, on a colder day, at the same track, with better motor mounts, runs better distance times then a previous run yet has no speed.... please can someone please me how that is even possible...
how I can get to every location faster then the previous run, yet my MPH is lower AND I run the same damn quarter...
Old May 18, 2007 | 04:26 PM
NmexMAX's Avatar
dot dot dot ...
MPH is typically related to high RPM power. Get a dyno.
Old May 18, 2007 | 10:03 PM
t6378tp's Avatar
Turbo 3.5
tailwind ......
Old May 18, 2007 | 11:15 PM
Nismo87SE's Avatar
Its called density altitude. You need to input the weather conditions from each day into here to see how much power your car was making those days.
Old May 18, 2007 | 11:46 PM
Merlyn's Avatar
And... I'm out
This information may be wrong... but using averages on info not on the slip this is what I got for yesterdays run
Relative HP = 100.4%
The first 14.290 I ran was
Relative HP = 100.1%
So you can see
First Time run The information (from wunderground.com)
Temp 83F (Timeslip)
Absolute pressure 30.06 inches HG
Relative Humidity 55%
Second time run
Temp 78F (Timeslip)
Absolute Pressure 30.12 inches HG
Relative Humidity 73%
(Used Average for pressure and Humidity)
Old May 19, 2007 | 12:49 PM
MikeSDA's Avatar
The differences in your 60" times between the two runs could also be a factor. Your higher trap speed run also has a slower 60" time...I will generally see the same thing, a higher trap with a worse 60 foot.
