1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Ran my modded 5.5 gen 6 speed
Old Nov 18, 2007 | 08:33 PM
maxspeedse02's Avatar
Thinks he is fast
Well I ran my max which I haven't done since all of the mods that I have done which are in my sig. My best run was 13.855. I know my 60' times can use some work. I took out my sub and spare tire. I did run two other times but the scan didn't come through one of which was a 13.9 against an 08 G35 sedan AT that ran a 14.00-14.2 all night the other was a garbage mis-shift run. Everyone was surprised to see me in the 13's. It was about 68 that night and I was trying to work on launching which clearly still needs some work. I was launching around 2.5-3k but not really feathering the clutch enough. I was shifting around 7k on the stock tach which is a little off and 2nd gear shift squealed the tires a lot.
These are the tires I'm running which are brand new ZR rated http://hankooktireusa.com/product/tire_detail.asp?pid=7
I put 45 psi in the rear tires and 20 psi in the front for a few runs and and 25 for a few others.
Feel free to add any suggestions, I would like to be in the low 13's, w/ BBMAF. I am also still on a stock suspension which is my next territory and reason for poor 60' times.
Old Nov 18, 2007 | 08:43 PM
pimpin02max's Avatar
Those are decent runs with those mods and 2.2 60'...get the 60' down to like a 2.0 and you might see 13.5
Old Nov 18, 2007 | 11:31 PM
96blkonblkse's Avatar
Damn those are pretty good times! 2.23 60ft is pretty good in a 5.5 6spd lol, if you can get that down to a 2.1 its very possible to hit a 13.5
I wish the local track here was still open
Old Nov 19, 2007 | 01:10 AM
AnDyMaN's Avatar
what size tire?
are you tuned?
Old Nov 19, 2007 | 04:20 AM
DasYears
those 60's arent bad for street tires. sure you can get it lower but 2.2 isnt bad. nice runs too, you should get it tuned next...(TS l-spec doesnt count)
Old Nov 19, 2007 | 10:06 AM
DandyMax's Avatar
3.5 in the works
Nice times, the sixty foots aren't that bad, but keep working on them. Suspension might help, and/or tie the fronts/block the rears to help combat front end lift/rear weight transfer.
Old Nov 19, 2007 | 10:26 AM
AceofSpds's Avatar
wat
Wow thats actually a good 60ft for those tires, i have them and they are a pretty hard compound tire.
Old Nov 19, 2007 | 06:22 PM
Thinks he is fast
Stock tire size and it was tuned but not with cattman rear section which is actually noticeably better on top end. I'm going to install the BBMAF and tune should hit 13.4-13.6. Thanks dandy I definitely intend in doing that next time at the track. Are the spring blocks actually made for that specifically or are they something from home depot?
Old Nov 19, 2007 | 06:25 PM
Thinks he is fast
The best run I had the tires actually at 20 psi which I thought was a little low I was taking air out and talking at the same time so I ran one tire down to 20 unintentionally. I found a guy with a portable compressor and put them back up to 25 and couldn't get better than 2.29 60'.
Old Nov 22, 2007 | 12:50 AM
AceofSpds's Avatar
wat
you can get them at any advance auto parts, and im sure any other retail auto parts store too
Old Nov 22, 2007 | 09:03 AM
Scottwax's Avatar
That's Mr. Detail to you
Trapping at 100+ ftmfw!
From your sig, just bolt-ons too.
Old Nov 22, 2007 | 10:24 AM
DasYears
lots of 5.5 6spds trap over 100mph. he could be trapping even higher...thats all im gonna say
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaxStock
Aug 12, 2015 08:33 AM
