1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Best tire and wheel combination
Old Feb 11, 2008 | 11:46 AM
KK1's Avatar
KK1
I have 4th gen. Max. and wondering what is best wheel + tyre combination?
Is it lightweight 15 or lightweight 16, is there much differnece?
If I take lightweight 15 I need to take higher tyre also?
Does it gives some effect?
If it gives effect then how much 0,5 sec per 1/4 mile or less?
Very much is used Kosei K1 15 inch?
If I take same weight 16 inch is it better?
Of course I plan take also lightweight tyre also+
aNY SUGGESTIONS?
Old Feb 11, 2008 | 12:38 PM
Ceasars Chariot's Avatar
Old Maxima Legend
16 inch rim or better yet a 15 inch like you mentioned. try to find rims that are 11-15 lbs each. will be considerably lighter than stock SE rims which are around 19-20 lbs. each.
It wouldnt be out of reach to drop a .5 but you would need to reduce your unsprung weight by at least 30-35 lbs off the wheel and tire combo and use a drag radial or slick up front.
Old Feb 11, 2008 | 02:33 PM
Nismo87SE's Avatar
If you drag race seriously, you should buy a custom set o lightweight drag rims (lenso, bogart). Tire choice depends on what power your car is making but a 24-26in slick is what will fit the bill.
Old Feb 11, 2008 | 11:27 PM
Nealoc187's Avatar
SLOW
the lighter and smaller the better - there's no other answer. 15" is as small as you can fit over a 4th gen brakes. get them as light as your budget allows.
Old Feb 12, 2008 | 09:49 AM
KK1's Avatar
KK1
But you drive in drag competitions 16 rims +tyres?
Howcam? Why don't you use 15 rims?
Old Feb 12, 2008 | 10:07 AM
DandyMax's Avatar
3.5 in the works
I'd say if you're getting a set of track only wheels, go 15"... otherwise if you're just running the same setup on the street as on the track (ie street tires) then 16" or your mileage will suffer (cruising at higher rpm). Either way, the lightest possible combo is best (as your budget will allow, like Neal said).
Old Mar 6, 2008 | 08:07 PM
QNO_A32's Avatar
i searched and found out that me stock 98SE wheels are 19.6 pounds.how much do the 15 inch steelys weigh?would it be wise if you were going to buy lightweight 15's, to just get two for the front?is that where all of the difference is,like the rears really dont matter.for someone on a budget,who was looking for track only wheels,would the millenia 15's be the best bet?thanks.................
Old Mar 7, 2008 | 03:48 PM
NmexMAX's Avatar
dot dot dot ...
Old Mar 7, 2008 | 06:23 PM
grey99max's Avatar
LandShark has Cosworth
Originally Posted by NmexMAX
34lbs per /wheel/tire for the Millenia and BFG 225/50/15 DR.
Old Mar 21, 2008 | 02:50 PM
QNO_A32's Avatar
thanks you guys
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
