1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
13.78@104 mph with the 3.5
Old Apr 19, 2009 | 05:25 PM
JClaw's Avatar
I got in about 12 or 13 runs. I have some winter tires on the car and they suck. 2.30 60 foot.
Best run 13.78 at 104.126 mph. Most runs were 1mid 14's@102-105 mph. Went 14.48 at 105.568 mph spinning badly. Went a bunch of 14.4's at 102-104. Also good 13.93@103.66 mph 2.31 60 foot. And 14.07@102.80 with a 2.53 60 foot. Track was cold. Almost no muscle cars, just a test and tune.
The car obviously has good power to be trapping 105. I removed the pass seat and some other stuff. AC, and the 3.5 is lighter than the 3.0 by 35 pounds.
Going back next weekend for a 13.5 on street tires. Should trap 106.
I also want to mention that I am using the OEM 4th gen clutch. I like it way better than my old 6-puck, much more driveable. I scored a 2004 Alti engine for 700 bucks. Threw it in in my driveway, drilled the stock 3.5 intake cams in a retarded position (welded all 4 dowel pins to the cams for more safety) and removed the butterfly valve in the intake. Im confident it will trap 106
Old Apr 19, 2009 | 05:31 PM
wyche89's Avatar
nice man.. what else do you have besides the swap?
Old Apr 19, 2009 | 05:43 PM
JClaw's Avatar
Y-pipe + 2.5" Cattman catback. It's untuned and runs pig rich. Car weights 2840 in street trim - I weight 160. The 5-speed is VLSD and has 130,000 km on it. Engine has 66,000 km.
I have some old avatar pics of the car:
http://www.myimagehosting.com/pic.ph...1XW7PF&i=35877
Those pics are from spring 2006 when I first sold it. The car now has a shaved trunk, Cefiro one-piece headlights and 205/65 winter tires.
Old Apr 19, 2009 | 06:17 PM
Jime's Avatar
Nice Stephan. I did a 12.6 @ 108 today so if you ran slicks you would be well into the 12's.
Old Apr 19, 2009 | 06:18 PM
Grand_hustle17's Avatar
must be nice... nice times
Old Apr 19, 2009 | 06:20 PM
t6378tp's Avatar
Turbo 3.5
nice times, with a emanage and slicks you may run 12's
I really need to make my car lighter and hit the track again
Old Apr 20, 2009 | 12:33 AM
one_fast_max's Avatar
nice man! definitely has potential there!
so you said the car will trap 106 next time? what will you be doing different to make this happen? just more practice? just curious what things you will tweak as i want to get better myself!
do you plan on SSIM and EU ? should definitely trap 107+ i would think
good luck next week!
Old Apr 20, 2009 | 02:35 AM
JClaw's Avatar
I am removing another 100 lbs from the car. I still need to buy a GXE master cylinder (no ABS) and an Optima battery.
Old Apr 20, 2009 | 05:21 AM
321VQ35MAX's Avatar
Nice runs. Can't wait to see what it does after tune. Keep us posted.
Old Apr 20, 2009 | 06:21 AM
kzoosho's Avatar
U know that some se's didnt have abs, I have two that dont. Good runs also.
Old Apr 20, 2009 | 07:39 AM
JClaw's Avatar
I dont plan on tuning it anytime soon. Maybe not even this year. But I will remove more weight because I think it has a 13.5 in it as it sits untuned.
Can you just tell me one thing - does the non-ABS master cylinder have all 4 lines directly plugging into it? The ABS master cylinder only has 2 lines going from the master to the ABS module, then 4 lines come out of the ABS module.
I should also mention that all 3.5 swappers should ground their knock sensors directly to the negative pole of their battery if they want uninterrupted, instant full timing all the time.
I have had several 3.5 swaps and when the car is untuned it runs rich and tends to have full timing only 50% of the time, sometimes none at all. I use 94 octane to be safe. 100% of the swaps I have done have had the intermittent timing power issue. This is why so many of the 3.5 swappers are dissapointed. They go from a preppy 3.0 with full on timing to a pig rich 3.5 with 15 degrees of timing WOT instead of 25. Nissan knock sensors suck, and they need to be dealt with.
There, I got it out of my system.
Old Apr 20, 2009 | 11:32 AM
grey99max's Avatar
LandShark has Cosworth
Good info on the knock sensor - I've noticed some timing "jitter" - not often but it has happened.
Nice to see you back.
Old Apr 20, 2009 | 11:39 AM
kzoosho's Avatar
I will have to look at one of mine to be sure but i think it does have all 4. Let me double check today and i can let you know.
Old Apr 20, 2009 | 05:28 PM
t6378tp's Avatar
Turbo 3.5
I have had several 3.5 swaps and when the car is untuned it runs rich and tends to have full timing only 50% of the time, sometimes none at all. I mix 91 and 94 octane to be safe. 100% of the swaps I have done have had the intermittent timing power issue. This is why so many of the 3.5 swappers are dissapointed. They go from a preppy 3.0 with full on timing to a pig rich 3.5 with 15 degrees of timing WOT instead of 3.5. Nissan knock sensors suck, and they need to be dealt with.
Mmmmm, guess that why Jime mounts his to the firewall or fender or somewhere I forget
I know is said sometime but not wanting the ecu messing with his timing, good info. So is it that the ecu does not provide a good enough ground
Old Apr 25, 2009 | 12:02 PM
DandyMax's Avatar
3.5 in the works
Welcome back Stephan..
Old Apr 25, 2009 | 02:41 PM
streetzlegend's Avatar
Is this referring to the full 3.5/ECU swap or those with 3.0 timing? because in my case, im running 3.0 timing equipment including knock sensor n stock 3.0 harness, and i get full timing (about 23 degree's WOT) all the time. Again, in MY case.
Old Apr 26, 2009 | 11:55 AM
JClaw's Avatar
Thanks guys!
Yeah it depends on a lot of things - but anyone experiencing intermittent timing should do that. It's no fun driving the car when it's like that.
I'm not hitting the track again until 2 weeks from now, few things to take care of...
Old Apr 26, 2009 | 12:21 PM
Nismo3112's Avatar
Custom User Title
Good time!! Glad to hear the 4.5 gen's posting awesome times.
Old Apr 26, 2009 | 08:29 PM
JClaw's Avatar
I just finished changing the stupid 95 rattle recall tensionner (FU!) and removing power steering cause it was pissing all over the place. I am NOT paying for a PS pump.
Old Apr 26, 2009 | 08:35 PM
denice25's Avatar
pretty cool....
Old May 11, 2009 | 01:33 AM
CMax03's Avatar
I probably need to lose some weight to make my 03 max faster! I'm 210 lbs and I need to get down to 175-180 lbs. Might gain .05 sec!!!
Old May 12, 2009 | 06:48 PM
speed racer's Avatar
pretty good on winter tires.
Old May 15, 2009 | 07:38 AM
chillin014's Avatar
nice traps! I thought the OEM 4th gen clutch wouldn't hold the torque of a modified 3.5 though. Whats your opinion about that? I was afradi to go with a Exedy Stage 1 because I didnt think it would hold.
Old May 16, 2009 | 07:58 PM
JClaw's Avatar
Get the 2001 clutch. Maxima 2001 5-speed, Production after November 2000 - straight from the dealer. It's got more surface area and 235 lbs more clamp force. Nissan uses it as stock but it's made by Exedy.
Old May 17, 2009 | 08:06 AM
chillin014's Avatar
thats what I've got on there right now but I was worried it may be reaching its limits after a few more modifications. You are saying it will hold over 300 ft lbs though?!?
Old May 24, 2009 | 12:10 PM
greattinger's Avatar
Those are pretty good times!
Old Jun 5, 2009 | 08:24 PM
ghostmax301's Avatar
mind posting what you did for weight reduction?
Old Jun 10, 2009 | 10:20 AM
JClaw's Avatar
Weighed car March 31st - Stock + Y-pipe & Catback - 3000 lbs flat with a quarter tank
2940 - Removed Spare + 20 lbs of carpeting and junk
2910 - 3.5 weighs about 30 pounds less than the 3.0L
2870 - Removed both bumper supports
2840 - Removed Sway bar & power steering
2835 - Removed rear passenger door window motor and stuff
2794 - Removed both airbags + Cut half of the support beam in the dash
You still need to leave the driver side part of the beam that holds the steering column
2794 lbs - weighted the car at aluminum recycler
Other things I did not do:
2775 lbs - Non-ABS Master cylinder (ABS module weighs 20 lbs)
2740 lbs - Remove passenger seat (35 lbs) TRACK ONLY
2720 lbs - Empty the rest of the rear doors
2693 lbs - 27 lbs Optima battery
At that weight the car still has NO CF ALL STEEL, a heater, FULL INTERIOR, and a functional electric moonroof - love that way too much to touch it.
Old Jun 10, 2009 | 11:13 AM
krazy6's Avatar
Damn, that thing is light!
Old Jul 5, 2009 | 06:08 PM
Jime's Avatar
Hey Stephan
Thinking about coming for the Battle of the Provinces. Just wondering if they have overnight camping for sat night. Long drive to get up early sunday and then race and drive home.
PS I am working on a version of your CAI idea, will show you sunday.
Old Jul 8, 2009 | 09:21 AM
HondaV6's Avatar
Wow the 3.5L weighs 30lbs less than the 3.0L!? I didn't know that!
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
09maxshawn11
Sep 30, 2015 10:28 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
