1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Removed USIM from 3.5 and put 3.5IM on, disappointed with track results.
Old Aug 3, 2009 | 10:22 AM
Nealoc187's Avatar
SLOW
I got my 3.5IM installed on my 3.5 swap finally, I had been running with USIM (3.0 Intake Manifold) before.
I made most of my runs with a VIAS block off plate installed.
EDITED with more analysis:
Before I edited this thread I said I was not too disappointed with the results but then I found the timeslips that I'd forgotten about from June of this year and I'm disappointed again.
I've never before corrected my numbers to sea level but I decided to see what the trap speeds correct to using DA correction.
In June I ran with the USIM installed and trapped as high as 101.74 with a DA of 1900' which corrects to 104.0mph. My traps on 8-2-09 were 102.x for the most part with some high 101s with a DA of 2200-2300 translates to 104.5-105.2mph I'm not sure what to think here. I would think that the addition of the USIM to the 3.5, with the ports being perfectly matched now and all, would be more significant.
Granted the car was about 70lbs heavier so that might be worth half a MPH or something, but I was hoping to see more. Also though I was on slicks this time as opposed to street tires, it's a different track, etc, so it's not the best comparison I guess. I'm heading to the same track as I went to with the USIM next week perhaps, so maybe I'll get some more data then.
Here is my setup:
95 SE 5spd
2002 3.5L with stock 3.0 cams, 3.0 ECU, stock timing, 3.5IM with VIAS block off plate, rough tuned to 12.2AFR because my laptop died and I can't tune my emanage right now
Homemade generic intake, y-pipe, 3" exhaust
26x10.5x15" MT ET Streets on 15" Welds ProStars
3050lb race weight
I can't wait to *possibly* get those headers modified and installed, and definitely get my Bikisoft ECU installed and really tune it. I think it'll move pretty well then but for now I'm a little disappointed.
Here is the breakdown of all the runs:
RT .017
60' 2.308 <--- lol
330 6.047
1/8 9.122
mph 79.88
1000 11.765
1/4 14.011
mph 100.41
RT .237
60' 1.975
330 5.559
1/8 8.569
mph 82.02
1000 11.17
1/4 13.364
mph 102.36
RT .030
60' 1.910
330 5.479
1/8 8.492
mph 81.71
1000 11.105
1/4 13.305
mph 101.79
RT .043
60' 1.918
330 5.487
1/8 8.501
mph 81.04
1000 11.112
1/4 13.322
mph 102.46
RT 1.705 <---lol I wasn't ready I was turning my camera on
60' 1.924
330 5.500
1/8 8.530
mph 80.63
1000 11.15
1/4 13.365
mph 102.24
For these last two runs I removed the VIAS block off plate and had the VIAS mechanism installed but the butterfly plate removed so it was just an open round hole.
RT .049
60' 1.863
330 5.452
1/8 8.491
mph 80.17
1000 11.117
1/4 13.342
mph 101.69
This run I short shifted the 2-3 shift at like 6300rpm just out of curiosity, it did not help
RT .071
60' 1.921
330 5.560
1/8 8.623
mph 79.56
1000 11.268
1/4 13.510
mph 100.98
Old Aug 3, 2009 | 10:30 AM
EnervinE's Avatar
i has college
Have you gotten the Biki ECU in yet?
Old Aug 3, 2009 | 10:53 AM
kzoosho's Avatar
Hmm i need some slicks too lol
Old Aug 3, 2009 | 12:14 PM
Nealoc187's Avatar
SLOW
Negative, has not arrived yet.
Old Aug 4, 2009 | 06:43 PM
one_fast_max's Avatar
neal that's weird....weather would have a big effect though....
i just did that intake manifold swap with just VIAS block off....it was 1700 DA it went 8.79 @ 83.23 in the 1/8th with street tires....
maybe the 3.0 cams are not helping at all now?? .......
Old Aug 6, 2009 | 07:39 AM
DandyMax's Avatar
3.5 in the works
Did I read that right... 3L cams?? That might be your limiting factor right there...
Old Aug 6, 2009 | 07:58 AM
Nealoc187's Avatar
SLOW
Could be but the difference in the cams is fairly negligable if my memory is correct, something like 8mm of duration and another .9mm lift or something along those lines. It's hard to judge with only one set of datapoints from a different track on a totally different tire size and style (bias at 10psi vs radial at 32psi). I was thinking of going to the track again this weekend but it's supposed to be 100 degrees this weekend so maybe not.
Old Aug 7, 2009 | 10:46 AM
Gemner's Avatar
.9mm lift doesnt sound like a lot, but considering they only open slightly more than 9, thats almost 10%, and 10% IS a lot
Old Aug 7, 2009 | 12:46 PM
96sleeper's Avatar
Tire size could be affecting you also. 26" slicks are probably not ideal for your car sans turbo. It seems like there are too many other variables also.
You are definitely not optimized right now anyway, between the weather, AFR, stock timing, 3.0 cams, etc. you might not be able to realize the extra airflow of the 3.5 IM compared to the 3.0 IM.
Old Aug 8, 2009 | 09:20 AM
JClaw's Avatar
Cams info, the three I've tried. I liked the stock 3.5 cams the best for driveability.
Stock 3.0 cams 8.55 mm lift
Stock 3.5 cams 9.5 mm lift
Aftermarket nismo 3.5 cams 10.7 mm lift
I can assure you that 70 pounds equals to .1 and 1 FULL mph on a maxima. Weight makes more of a difference than you think, I could feel a 40 lbs difference off the front end while driving the car.
I blew my engine BWAHAHAHAHAHAHAHAHAHAHAHAHAHA
I hate you.
Justin Kroll
Sep 2, 2015 11:06 AM
coasterswim
Sep 1, 2015 05:27 PM
jholley
Aug 30, 2015 06:39 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
sc10692
Aug 9, 2015 09:37 AM
