1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
shift points for 5mt vq30
Old Sep 23, 2009 | 04:46 PM
Shift_Knob's Avatar
i read the post at the top in the sticky and all it said was to redline 1st and short shift the rest but how short? if i remember correct power on a stock vq drops off at about 4500 rpm? so im guessing shift points should be about 4500-4600 right?
wow fail title screw up i meant vq30 lol
Old Sep 23, 2009 | 05:48 PM
Nealoc187's Avatar
SLOW
wow you are right I didn't notice that it didn't give actual RPM, I just edited the sticky.
anyways, no, power drops off after about 5500rpm. optimal shift points with USIM are about 6300ish from 2nd to 3rd and 6100ish from 3rd to 4th. i fixed your title too.
Old Sep 23, 2009 | 07:12 PM
Shift_Knob's Avatar
thanks u said their was supposed to be pics in the write up that were broken so i suspect that they had the shift points explained in them.
edit: this might not be the right place to post this but what is redline on a 100% stock motor? i think i hit the revlimiter at about 7k or so but if that is the limiter it must e a "soft touch" it seemed like the motor just ran out of ***** to go any higher. i just like bouncing limiters so u know when u hit it.
Old Sep 23, 2009 | 08:37 PM
MorpheusZero's Avatar
Rev limit on a stock motor is 6550rpm, where the redline starts. The tach reads a little higher (usually around 6700rpm for me).
Shift points are all with the VQ30DE. 00VI it and smack it off the limiter before every shift.
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
