1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
5.5g Auto Maxima
Old Oct 20, 2012 | 07:01 PM
nishfish871's Avatar
5.5g Auto Maxima
First time out to the track.
Dallas Raceway Oct 20th 2012
Density Altitude: 2500 feet
Relative Density: 92.89 %
Best:
R/T 0.450
60ft 2.223
1/8 9.320
MPH 76.43
1/4 14.458
MPH 93.75
Stock and Mildly Modified Naturally Aspirated Engines
13.975 @ 96.666 MPH
Extensively Modified Naturally Aspirated Engines
14.116 @ 95.728 MPH
Most of the other runs where in the 14.5's. Got about 15-20 runs in.
Mods:
3" BRM Exhaust
3" Testpipe
Gutted Cats
3.5" Intake w/ Velocity Stack
LRMAF
Ghetto BOP
NWP 3pc Spacers
NWP Torque Link
SSIM
350z Fuel Injectors
VAFC2 w/ Zeitronix ZT-2 Wideband
Street Tune to low 13 AFR
DR Mod
Next mod: HEADERS
Old Oct 20, 2012 | 10:35 PM
MrEous's Avatar
^ Jeff™
Maybe we should hit up Ennis next time...no other changes and I bet you're down to 14.2
(prep at Dallas Raceway is sucking)
Old Oct 21, 2012 | 06:54 AM
7speed's Avatar
Next mod: HEADERS
Yeah you got some nice run, especially for your first time.
Don't do headers, you already gutted cats. And car sounds real nice as it is.
Old Oct 23, 2012 | 05:31 AM
MrEous's Avatar
^ Jeff™
Old Oct 23, 2012 | 05:25 PM
Originally Posted by MrEous
I shifted into 2nd way early...I think the ricer noise got to my head
That civic had slicks and some secret sauce.
On a good note, that was a badazz launch by me.
Old Oct 24, 2012 | 10:09 PM
Rods03Max619's Avatar
Nice man, our 1/4 is shut down for a moment might have to hit a 1/8th....
Old Dec 6, 2012 | 05:08 AM
datdude20's Avatar
That makes no sense. Gutted cats a temporary solution for horsepower. For maximum performance out of a n/a maxima headers are a must.
and lighter wheels would help a lot 2
Old Dec 6, 2012 | 07:35 AM
Originally Posted by datdude20
Thats makes no sense. Gutted cats a temporary solution for horsepower. for maximum performance out of a n/a maxima headers are a must.
I got headers now. Track wheels are on the list to do after I beef up the valve body. Too much slip between gears, it's hard to predict when to shift.
Old Feb 6, 2013 | 07:33 PM
Azmax61's Avatar
Lighter wheels. A full set will shed good weight. Not just fronts.
Old Feb 7, 2013 | 06:42 AM
Grand_hustle17's Avatar
incorrect info......
Old Feb 7, 2013 | 03:21 PM
NmexMAX's Avatar
dot dot dot ...
Anyone notice this OP was dated 10/20/12, but the run was 10/22/12? How does that work?
Iw as just trying to find out a DA for that day, but, ahh, was a little weird when I looked.
Old Feb 8, 2013 | 12:38 AM
MIKERNM1990's Avatar
I must disagree with you. His car must have something wrong because his timeslip isn't correct. He should make 13 sec in 1/4 mile and trap more than 100 mph. He went 76 mph in 1/8 mile. My Nissan (auto) went near 80 mph w/ kn drop in filter only.
I see FlawleZ made 14.448 @ 98.12 mph w/ only a K&N drop in filter, GAB, NWP VIAS, and NWP Spacers. Click below:
http://forums.maxima.org/1-4-1-8-mil...ather-win.html
Few mods = good timeslip and many mods = bad timeslip. It isn't make a sense.
EDIT: @admin/mods I don't argue w/ here. Just discussion.
Old Feb 8, 2013 | 05:52 AM
bryanakaslim's Avatar
The car is probably not hooking for s***. He is probably spinning first gear
Old Feb 8, 2013 | 07:03 AM
NmexMAX's Avatar
dot dot dot ...
2.2 60' doesn't really imply that he's spinning all of first.
There are mods that would help, other than power mods.
Driver, weather, tire, and weight mods help too.
Old Feb 8, 2013 | 10:46 AM
If he has coilovers he can stiffen out the rear
Old Feb 9, 2013 | 11:46 PM
To answer all questions, yes something is off on my car. I believe it is timing related, I got a cipher and will do some logging to get to the bottom of it. If it's not timing, I would assume the motor is on its way out (burning too much oil).
Updated the OP to include the correct date and DA.
Old Feb 9, 2013 | 11:54 PM
Good Luck on figuring it out man...
Old Feb 10, 2013 | 09:25 AM
7speed's Avatar
LOL yeah I know he already had the headers in the works. Just messing with my boy.
But yeah Nish at least the dyno showed you something is up.
Old Feb 10, 2013 | 11:56 PM
What was the Dyno numbers, got the Graphs so we can have a look....
Old Feb 11, 2013 | 09:26 AM
It was below 200 on a dyno dynamics. MrEeous dyno'd also with me so we can confirm the dyno was off but not completely false. He dyno'd 235ish, if I remember. Little low but you get the point.
I have since removed the VAFC and LRMAF, and am pleased to say I got a big increase in the butt dyno. With this setup the timing was 25 at redline, and the afr stayed steady at 13.3 and dropped down to 12.8 at redline. Pretty wild for a untuned maxima, must be the 3.5" intake or 350z injectors.
I do not have a timing curve for the dyno/track setup, assumed it was significantly lower.
Now if I can get this dam UTEC going...maybe I'll gain a lot with a more aggressive timing curve.
Old Feb 11, 2013 | 07:31 PM
Most all people say DynoDynamics reaad lower than DynoJets, but I would say must be the 3.5LRMAF, I'm using the 3" one and when I slapped it on lost 10hp and 10tq so took it off till got the Neo installed, but have the Z injectors also no problem running those Untuned, but got it Dyno Tuned now hit about 242-243ish on a DynoDynamics, waiting for time so I hit up a DynoJet.
So was your car Tuned with the LRMAF or no when you hit the Dyno? After Tuned usually people make some nice power with those.
scutmud
Aug 16, 2018 10:56 AM
Maxilano
Aug 31, 2015 07:33 PM
BobMax
Aug 19, 2015 04:39 PM
Hawkeye61
Aug 12, 2015 06:45 PM
