Mechanical/electrical Problem
Old Aug 21, 2002 | 06:16 PM
CoolBeans's Avatar
Hey Guys,
I have the opportunity to acquire a 1985 Nissan Maxima from my father. The only catch is that there is problem that happened recently that has caused most of the electrical systems not to function. The car still starts, but the fans, lights, radio, AC and security system do not work. Also, the car exhaust smells very strong. It seem that about 1/4th of the fuse box is receiving power. Does anyone have an idea as to what could be wrong? If it is a cheap fix, I will have it repaired, otherwise I am going to donate it and take the tax write-off. Any help would be greatly appreciated!!
Old Aug 21, 2002 | 09:27 PM
alllw86's Avatar
Re: Mechanical/electrical Problem
Originally posted by CoolBeans
Hey Guys,
Have you checked the fusible links, I'll bet one of them is burned/open and not letting the 12volts get to the other fuses. The fusible links are easy to get to and check, located on the driver side in the engine compartment, on the fender. There may also be one on the Battery terminal connector. Looks like a small loop of wire, heck that what they are. Anyway check them out and if you do find one bad, now you have to find out why it went bad. Could be the alternator, a short some where, anyway start with the fusible links.
Good luck, Al
Old Aug 24, 2002 | 08:03 AM
Brendan's Avatar
This will sound dumb but make sure the switch for the fuse box inside the car is on. Just tryin to help man.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
