?S about ecu's
Old Nov 9, 2002 | 12:46 AM
2ndGen@10psi's Avatar
?S about ecu's
aight im halve way stocked on the parts i need But heres the deal i didnt buy the z31 engine i decide to just build my motor for the right compression and everything else i needed.. aight #1 would i be able to run the z31 comp on my stock wiring harness.. #2 how easy is it too install the turbo fuel pump and would i be able too go with the z32tt fuel pump cuz i aint found **** on these two subjects
Old Nov 9, 2002 | 01:41 AM
Nismo87SE's Avatar
Yes you can run the z31 ECU, however you need it add 1 wire from the knock sensor that goes in the left head to the ECU pin #29. I'm sure the TT fuel pump installs simularly to how a maxima fuel pump is installed.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
