turbo on 2nd gen
Old Nov 24, 2002 | 01:02 PM
Brendan's Avatar
turbo on 2nd gen
how much does it cost to add a turbo to a 2nd gen, approximetly. Also how much boost does it give the max? Anyone know what it would improve times to?
Old Nov 24, 2002 | 07:00 PM
Nismo87SE's Avatar
I believe $3-4k is about right for a turn key turbo conversion if you don't do the labor yourself. What you do is buy a VG30ET or at least the manifolds + turbo. Get a Z31 turbo ECU/fuel injectors and add a wire that runs from the Knock sensor (you will have to install this part) to the ECU's pin #29. Finally get a walbro fuell pump and you should be set. The extra $1-2k would cover the fabrication work for the exhaust piping and intake if you must have an IC.
Old Nov 24, 2002 | 08:09 PM
Brendan's Avatar
any idea on what it does in the way of times?? thanks for the info though
Old Nov 28, 2002 | 01:12 AM
ASHURA's Avatar
here's what I found recently. see if the guy still has it if anyone still interested.
http://www.race-cars.com/partbd/messages/6272.htm
Old Nov 28, 2002 | 02:58 AM
Nismo87SE's Avatar
Ok given the stock turbo + bolt ons and 11-13psi, an auto would run around low-mid 14s. A 5spd would probably run low 14s.
Old Nov 28, 2002 | 05:06 PM
Brendan's Avatar
awsome, thanks man
Old Nov 29, 2002 | 09:07 PM
2ndGen@10psi's Avatar
which tranny would hold more power the auto or the manual i wanna go manual ...but i dont want the 5 speed to break on me
Old Nov 29, 2002 | 11:56 PM
ASHURA's Avatar
Auto. more fluid = more dampening agents.
Old Nov 30, 2002 | 01:28 AM
maximase86's Avatar
I love lamp.
Well, it's kind of preference sort of. The 5-speed will definately be quicker, but like you said, it will have a tendency to go south if you don't do something to it to take the power. The auto would do nice, but if you want to car to have great performance, you might want to do the Level 10 mod for it. It will essentially make the auto bullet proof.
Sarin
Old Nov 30, 2002 | 03:00 AM
ASHURA's Avatar
BTW, autos are more efficient on the drag strip, mainly because you keep the throttle floored while shifting. Doing such on an MT car will spell trouble @ high boost levels.
Old Nov 30, 2002 | 10:22 AM
Charles Bisel
Yeah, auto is definitely the way to go. I believe some shop in California that mods Nissans tried to turbo a car with a stick. The third gear ended up getting ground down smooth.
But like Sarin said, you'd have to go with a Level 10 rebuilt tranny (or something along those lines) in order to handle a good deal of horsepower, I really doubt that the stock transmission can.
-C-
Old Dec 1, 2002 | 11:38 PM
hlh0501's Avatar
I do not know if the 2nd gen is anything like the 4th gen, but 5spd would be the preference with a 4th gen.. or else having a really built automatic.. my stock 5spd tranny is holding well over 400hp and many trips to the track already.. our 5spds are very strong, whereas a stock automatic in a 4th gen would be worthless in a matter of no time..
fyi: i am the guy offering the turbo kits for 4th/5th gen maximas...
www.hlh0501.com
Old Dec 2, 2002 | 07:35 AM
maximase86's Avatar
I love lamp.
Another thing that I wanted to mention. If you plan to do the turbo, and want to use the 5-speed, I highly recommend doing a 5-spd swap with a 3rd gen 5-speed. The synchros in the third gen are much better, and the gear ratios a tad bit closer together, though not by much. It is possible to do the swap, because I've done it with my 86 when the original transmission bearings went out. Things you will need to look out though. The second gens have 2 mounts, where the thirds have three, the speedometer in the third gen is electronic, so you have to swap that out with your old one, last, the shift linkage is the different, so you have to swap that out with your old one. One tip, make sure who ever does your car that they do the clutch right, or you will have a really nice shifting problem, and make sure they hook up your reverse lights. I still have no reverse lights, and I don't have the time to figure out how to hook them back up.
Sarin
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
ik95
Sep 16, 2015 08:11 PM
A32goldylocks
Sep 14, 2015 06:49 PM
