1st gen mods
Old Oct 1, 2008 | 09:24 PM
  #81
matt for maxima's Avatar
yer it a second gen it goes really good but i think it could go better a...could go with computer nd injectors but after that what else...o yer its a pillarless modle not very many around new zealand
Old Oct 1, 2008 | 09:34 PM
  #82
yer its a second gen pillarliss model...could do injectors and computer but i was woundering if a 300 zx motor will bolt in weith out any hassles....my wife reconds it goes really good now and she told me not to do any more to it but i just like speed and the nissan is really good to start with and the sub is all electric to
Old Oct 2, 2008 | 02:59 AM
  #83
Big_E-Dog's Avatar
2nd Gen Boostinator
if your legrand is turboed already then it should drop right in your lucky if you have the 2.0l turbo motor because youll have all the mounts worked out all youll have to do now is to alter the downpipe.
Old Oct 7, 2008 | 11:23 PM
  #84
yer it is 2l..so 3l would fit straight in then...i brought this car off my best mate but had a lot of work to do to it....hot the car for $3000 then the gear box blow...then the motor...so i repainted it and dropped in a new motor now doesnt go to bad...got front mount intercooler boost tap and blow off valve should i up grade of just keep it like this
Old Nov 25, 2008 | 08:34 PM
  #85
clazcar's Avatar
My 81 Turbo Max
Hello guys, just joined this awesome site because while surfing the net. I ran across this site that had my car posted on this site So I just want to introduce myself and show my old school maxima with a L28 turbo smog legal with a california smog certificate sticker on it. So everything is legal on this maxima. And I just want to apologize to the tread starter for hi jacking your post. I just can't start a new thread, the site won't let me. Thanks again and hope you like this old school maxima. Here are some pictures, check the link below. Thanks again
http://s459.photobucket.com/albums/q...maximus003.jpg
Old Nov 25, 2008 | 10:00 PM
  #86
DIASISS OF JASSICS.COM's Avatar
your maxima is mindblowin!!! 10stars!!!
Old Jan 20, 2009 | 08:10 PM
  #87
HowlerMonkey's Avatar
That white one looks good but those wheels rub like a *****.....been there with those exact same rims. Maybe if he used 280zx offset front and rear brake setup and front struts with the 280zx offset he wouldn't have the rubbing.
Might be selling my first generation turbo l24e 5 speed car with r200 rear.
It's high mileage with worn control arms that allow the ball joints to move a bit, has noisy brakes, chattering and worn 4 puck clutch, worn turbo that still works but it has reliably driven me to and from work 25 miles each way every day for the last 2.5 years.
It sports 15x6 300zx 4 lug wheels with worn 215/50s (225/50 would have been better).
Body has dings but no accident dents and I have tons of replacement parts and the unibody floor has no rust holes.
Price will be sub-$500 but I will take it to moroso this weekend and see what kind of offers I get after smoking a few s13s before releasing it here.
Oh and one more thing.......when converting a L28 from rear to front sump, don't drill the dipstick boss that looks like it would be the proper place.
The L28 block has two oil pickup tube bosses with the front one being blank since the engine was always used as a rear sump application.
When converting it to front sump, sure...you can drill out the front boss but you have to remember the oil galley still continues to the back boss which must be blocked off and.....................it passes right through the dipstick boss where one would drill the hole for a front sump.
The front dipstick boss is for use in an engine that was only drilled to the front pick-up boss.
If you drill the front dipstick boss and the front oil pick-up boss in the L28, you must shove a plug into the galley just after the front boss or your car will gulp air through the now drilled dipstick boss.
I just cut the pickup and turned it as well as extended the one inch necessary to reach the front sump and drilled a front dipstick hole where there are no oil galleys present.
For fun, the engine will be sporting the very racy twin dipstick look.
It goes in my M30.
Old Jan 28, 2009 | 09:09 PM
  #88
clazcar's Avatar
Hello HowlerMonkey, I don't have any rubing issue on my maxima, never rub ones. My car is not lowered and I'm running 195/60/15. Also, I have another maxima, an 83 with the same turbo wheels but this car is lowered and no rubbing issues at all. I'm still runing the stock brakes set on both my cars, 81max and 83max. Take care guys
Old Feb 2, 2009 | 11:03 AM
  #89
Strange........those exact wheels with the same size tires rubbed in my maxima.
I gave away 8 of them recently because I no longer had a car they would fit.
Now the early 300zx wheels will fit 225/50s and not rub.
Old Feb 10, 2009 | 12:40 PM
  #90
sweetnesschild's Avatar
I just bought an 82 maxima.. i really want to lower it and start doing some work on it but i dont know where to start
Old Feb 10, 2009 | 04:50 PM
  #91
Just fill it up with gas and it will lower itself.
Old Feb 12, 2009 | 12:27 PM
  #92
is there any coilovers or spring sets i could buy?
Old Mar 5, 2009 | 07:00 PM
  #93
tremaine87's Avatar
Guy whats up, Namez Tre, Im about to pick up an 87 Maxima (man trans) for free in Cali, jus want to get on these forums & meet 1st Gen Maxima drivers. I actually want to mod it w a turbo, intake, body kit rims, the works.
So ill posts picks of it the friday frm today!
Hit me up if u have any insight 4 me, Thx Every1
Old Mar 27, 2009 | 06:20 PM
  #94
mahanddeem's Avatar
nice
Old May 22, 2009 | 09:28 PM
  #95
comrade_Charlie's Avatar
Pretty sure 87 max is a 2nd gen
Old Jun 17, 2009 | 02:04 AM
  #96
awdrftr's Avatar
well it looka like i will be adding to this, 5-22-2009 was the last post. Does anyone go in here anymore? My name is Mykol, from Socal Orange County. I was searching for a place to introduce, but i had no luck. Since i have a 1st gen Maxima, i thought that this may be suitable. So far i have been playing with sportscars for years, well since i was a kid. I was super stoked when I found my first RWD nissan Maxima. Datsun 810 is what i believe what others may call it. Recently I have accumulated a lot of networking and got this moving slowely but cheaply. Got sideskirts, fender flares, spoiler, Kaaz LSD for the r180 diff. , and recently picked up a 2JZgte motor to swap into it. im mainly concerning myself with the looks for now, since i have both an s13 and fc3s to play with while i work on the Maxima. im going for the VIP Drift style. in that scene looks mean a lot, and my buddies drift their 82 Cressida 2jz swap, Infinity M30 LS1 swap, and Cefiro rb20 swap, and i know no one that tunes or drifts maximas. mainly cuz most of them are FWD. no offense, i just like to drive RWD.nice to meet your forum, i'll post pics asap. peace Mykol
Old Aug 5, 2009 | 08:18 PM
  #97
If you have a 2jgte, then you will need to fit the R200 diff. to the car.
The S12 200sx turbo R200 diff. mount and late 280zx C/V type axles will much better handle that engine without breaking.
Old Sep 2, 2009 | 01:54 AM
  #98
Te72Rob's Avatar
I just picked up a first gen. Stripping the interior, dropping in a 280zx L28 and 5speed. 86 300zx suspension/5lug swap. hopefully be done in less than a month
Old Sep 14, 2009 | 10:02 AM
  #99
5genflaboy's Avatar
Just got a 1982 datsun maxima with a diesel in it. don't know anything about them, I'm learning. i need a alt. for it anyone have or know where i can find one?
Old Sep 14, 2009 | 04:14 PM
  #100
arsonist63086's Avatar
autozone my freind...
Old Dec 19, 2009 | 04:25 PM
  #101
TeKKiE's Avatar
Just getting up the post count...
Old Dec 19, 2009 | 04:26 PM
  #102
TeKKiE's Avatar
Inherited an '84 Wagon (I think '84? Could be an '83 I guess?)
  #103
TeKKiE's Avatar
Comes with the L24e that I know of, autotragic.
Old Dec 19, 2009 | 04:27 PM
  #104
TeKKiE's Avatar
Haven't really decided what to do with it just yet...
  #105
TeKKiE's Avatar
I've been looking everywhere for examples of wagons and modifications...
Old Dec 19, 2009 | 04:28 PM
  #106
TeKKiE's Avatar
Definitely not new to Nissans, in any way. I drive a 400+whp 98 200sx SE-R, and an '05 Armada (tow truck).
Old Dec 19, 2009 | 04:30 PM
  #107
TeKKiE's Avatar
Okay well this is going to take me forever, just so that I can create my own thread
So who here still owns a wagon? Anyone know of any sites that deal more inherently with the wagon? I've seen VERY FEW pics of them floating around on the web. I want to keep it simple, and want to keep it N/A. I don't need more boost in my life.
Old Dec 19, 2009 | 05:21 PM
  #108
chrome91's Avatar
honestly i think you will have trouble finding a Maxima wagon only site, the 1st/2nd gen forum is nearly dead already so i think this is about it.
if you dont want something fast, i would personally lower it and get some low offset rims, if youre into it you could even go bosozoku with it
Old Dec 19, 2009 | 09:27 PM
  #109
MAX.Graff's Avatar
How ironic that I was just thinkin' about the wagons.
Now those, are super rare!
What is it that you're tryin' to get help with?
Old Dec 19, 2009 | 10:38 PM
  #110
chrome91's Avatar
There was a Maxima wagon on the final Pimp My Ride, not my style though. IMO Pimp My Ride was usually bang on with the tranny and engine work they did, but they always went overboard with the interior and paint jobs. and like with the interior, i want Sparco seats under my @ss, not LED's
Old Dec 19, 2009 | 10:58 PM
  #111
MAX.Graff's Avatar
Nice one Chrome.
Didn't that car get sold? Didn't they put some wack body kit on it?
Old Dec 19, 2009 | 11:06 PM
  #112
chrome91's Avatar
Originally Posted by MAX.Graff
Nice one Chrome.
i dont really know, way back when i saw like 10 minutes of it on TV and i was tired as hell
i wonder if the people who get their cars chosen for Pimp My Ride have to sign a paper that they wont sell the car for X amount of years? i would just buy some beat up rusty domestic boat, let em take it, act surprised in the end and sell it for $30,000 and buy a JDM R32 Skyline and drop in a bunch of mods
funniest @ss one was the guy with 2 car halves welded together, they couldnt fix the dam thing it was so unsafe so they just gave him a new vehicle
Old Dec 20, 2009 | 01:47 PM
  #113
MAX.Graff's Avatar
I remember that one. It's sad that he had a welded car... Even sadder to find out that the halves were different years.
Wish they could of given me a new MAX!
Old Dec 20, 2009 | 02:56 PM
  #114
MAKE {SURE} YOU CHANGE YOUR TIMING BELT!!!!!!!!!!!!!!!!!!
Old Dec 20, 2009 | 10:12 PM
  #115
chrome91's Avatar
and he even let his kid or little brother or whoever in it, i would freak out just being around that thing. how hard is it to get a sh1tty real whole car like a 1990 Camry that will last you another 5-10 years for $800
I wouldnt mind getting free/cheap parts from getting my 3rd gen sponsored like JoeBoost did, that would be pretty sweet. problem is you where i am you usually need a JDM car to get noticed
what i wouldnt give for Nissan to make me 3 custom cars, a 1st gen, 2nd gen, and 3rd gen, all RWD RHD with a L series Inline 6 Turbo. Kinda sucks Nissan killed RWD off after 1st gens
Old Dec 23, 2009 | 01:43 PM
  #116
edz280zx's Avatar
New guy here...just thought I'd say hi....
Old Jan 21, 2010 | 09:27 PM
  #117
kuntryboy89's Avatar
rb25 swap
has anyone had any success with an rb25 swap?
Old Jan 21, 2010 | 09:37 PM
  #118
chrome91's Avatar
theres a guy almost done a RB26 swap on his 4th gen but thats different because 1st gens are RWD and came with the I6.
i would say its very possible, both being Inline 6 there shouldnt be many fitment issues. wouldnt a RB20 maybe be better?
Old Feb 21, 2010 | 08:43 AM
  #119
LeX's Avatar
LeX
Nissan by Nature
Rb20 is the easiest just cause wiring is easier, tranny is physically smaller, and motor is a bit shorter in the height department.
It almost drops right in. For fitment it needs to move forward about 1/4 inch from where the L series sits so i'm having brackets made
power steering and heat and AC are all easy to hook up... AC you just need new fittings.. I think the lines will reach for both PS and AC
Old Feb 21, 2010 | 09:46 PM
  #120
chrome91's Avatar
man thats actually a good swap then, used RB20 for $500, good 1st gen for $1000, swap it in yourself and you have a fast car for $1500ish
