No clutch peddle effort
Old Jan 27, 2003 | 11:56 AM
MrSmith's Avatar
Please forgive me, I tried the search button but it keeps saying unable to find what im looking for.
OK. I have a 86 maxima, The clutch peddle goes to the floor with no effort, I have replaced the master cylinder and checked the lines I have no leaks. I went to the front of the transmission and pressed the Clutch release cylinder with my hand and heard the fluid move in the master cylinder. So im not sure whats going on. My Hayne manual doesnt say so, but can someone tell me if the gear oil has anything to do with the pressure in the clutch peddle??
Old Jan 27, 2003 | 12:02 PM
KALSC's Avatar
Hmmmm . . .
Well, if you can HEAR the fluid moving, chances are you have air in the system. If there is any or enough air in the system, the pedal will go to the floor with minimal/no effort and the slave will not push out to swich the clutch fork.
That being said, have tried to properly bleed the clutch fluid?
Old Jan 27, 2003 | 01:38 PM
maximase86's Avatar
I love lamp.
Re: Hmmmm . . .
Also, did you check your slave cylinder, those go bad too. They usually develop small leaks. Also as KALSC said, double checked you bleeded the system properly. Also when you installed the master cylinder, did you remember to bench bleed that too?
-S
Old Jan 27, 2003 | 01:45 PM
KALSC's Avatar
Good point.
Good point about the slave going bad, that happened to me too, in traffic!!!! The diaphram in the slave got a tear in it and fluid went through the tear instead of pushing the pin! This happned while in traffic too!!! Good thing I was able to pull off and limp to my father-in-laws gargage where I rebult the slave with a kit. It was a cheap fix, all in all the rebuild kit was $7 CDN.
Old Jan 27, 2003 | 03:03 PM
maximase86's Avatar
I love lamp.
Re: Good point.
Definately. When I had my transmission changed, the guy found that the old slave cylinder was leaking, though not a lot, it was leaking. These things probably see more use than your brakes do because of all the shifting. Just beware, the slave cylinder is a PITA to get out because it's right under the front exhaust manifold.
S
Old Jan 27, 2003 | 08:03 PM
MrSmith's Avatar
Re: Re: Good point.
S
What does PITA mean?
I find It hard to bleed because I have No pressure when stepping on the peddle, Is there another way I can do this??
Old Jan 27, 2003 | 08:10 PM
KALSC's Avatar
PITA - Pain In The A$$.
Put it this way, is you open the bleed valve on the slave and then press the pedal, does any fluid come out? Does it spit a little? (air bubbles)? Or absolutely nothing?
Old Jan 27, 2003 | 08:18 PM
MrSmith's Avatar
Nope I didnt open the bleed valve, I did remove the slave though and disconnected the line and fluid came out when I pressed the peddle. Fluid is also seen rising in the reservuor(or how ever you spell it)when I press the slave in. is the cylinder suppose to move left or right when you press the peddle
Old Jan 29, 2003 | 10:50 PM
dr.disc's Avatar
Right.
Old Jan 31, 2003 | 01:54 PM
MrSmith's Avatar
Thats confusing to me, When I try and push the cylinder to the right with my hand It doesnt move, but will move to the left. I suppose that when the peddle is pressed, the boll joint pushes against the cylinder causing me to be able to select gears. AAAHHHH, I dont know
Old Feb 3, 2003 | 11:15 PM
MrSmith's Avatar
Had to get another dang clutch master cylinder. Bleed it and its top notch now
user 11122324
42
Jul 18, 2022 03:35 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
06maxima55
Sep 28, 2015 04:29 PM
carlosvq30
Sep 26, 2015 09:44 AM
lkiller123
Sep 21, 2015 03:00 AM
