keyless entry???
Old Mar 20, 2003 | 02:21 AM
u-turn's Avatar
keyless entry???
hi guys i was just wondering if anyone knows how i can get the set code for my keyless entry sys. thanks
Old Mar 20, 2003 | 08:40 AM
spacey64's Avatar
Re: keyless entry???
ok here is wut u do...
pop trunk in the center of the rear deck (underside that is) there is a lil box which should have a # starting with F copy the last i belive 7 digits down,
then go to ur key pad press "ST" then punch in the code if it doesnt work than its the last 5 digits, if u hear a longg beeeeeeeeeeep
then u punch in a 5-7 digit # BUT U CANNOT use the same key twice (meaning key shares a #) it has to be a sequencial thing,
then when ur done pressin ur personal code press st again and it should beep a few times n ur all set
after that jus try it out
if im wrong ask charles he is the one who explain it to me the first time
~mike
Old Mar 20, 2003 | 01:24 PM
Charles Bisel
Damn, I wrote a good explanation on this forum about how to do that, but with the search feature gone, I can't find it. Max88q - if you manage to find that post, feel free to put it in the FAQ section, I've answered that question at least 6 times already.
In the interim, I answered the keyless entry question at the club a while back, so you can do a search for it over there. I'll eventually get around to putting an FAQ with that information at the club as well.
Spacey did a pretty good job explaining it, there's only a few corrections I need to make. For one, you can use a 4-7 digit code (not 5-7). Also, it is the full 7 digit F#. And you don't have to press ST when you're done entering your personal code, just type it in and let go, it should beep a few times if it is a good code.
-C-
Old Mar 21, 2003 | 05:59 AM
u-turn's Avatar
Thanks alot worked perfect but the drivers door does not lock or unlock with keyless or the lock switch on my 85 why???
ah2002
Mar 9, 2016 01:42 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
