Engine dies sporadically!!
Old Jun 22, 2003 | 06:38 PM
chrisjohnson's Avatar
Need any Feedback or Suggestions!
Problem:
My '88 5-speed dies sporadically while driving from 45min to 3+ hours.
The RPM's Drop and it looses power causing me to pull over. (It does not always happen. More often after a rain.) When I flutter the gas pedal it intermittently causes the RPM's to increase and then it falls off. Idles rough and usually dies. Thought it might be water in the tank/lines. Replaced the Fuel Filter numerous times, Installed new tank as well as an in-line Fuel/Water Separator (Seemed to clear it up for a while.) Drained the Separator and no indication of H2O.
Replaced: Coil, Plugs, Wires, Cap/Rotor and waterproofed the Cap. (Cap was dry on the dying occasions.) Cleaned and emery clothed Rotor/Cap contacts. Changed Fuel filters, Drained the Fuel/H2O separator. No H2O. Roadside Triage done with engine off, about 5 min. Engine starts right up and it seems to clear up the problem for a while BUT it returns.
Any Help WILL be greatly appreciated.
I don’t want a F.O.R.D. (Found On Road Dead)
Thanks, Chris
shilov
Feb 19, 2024 09:40 PM
sctludwig
Sep 1, 2022 01:32 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
