Loud Noise Got Need Help
Old Jul 13, 2003 | 10:39 AM
VEGASLA's Avatar
I have a noise when i start a car keep making the noise sounds like the noise is coming from the one of the belts anyone had the same problem.
Any one with the skills know what the problem is, its a loud sound lke the belt but i dont know
Old Jul 13, 2003 | 04:36 PM
max95q's Avatar
Ok lets try to describe the sound it makes, screetch, squeel, moan, grinding what? Weve determined the noise part already
Old Jul 14, 2003 | 12:59 AM
VEGASLA's Avatar
screetching
Old Jul 14, 2003 | 01:22 AM
blackmaxima88's Avatar
sounds like a belt just needs to be tightened. try to figure out which one, you have 3 to choose from. run your fingers down each belt and feel if any are loose. they should be tight - but not too tight.
with the engine running, turn on the A/C. if there is screeching (the lights may also dim and/or the voltmeter may drop) then it's the compressor belt.
with the engine running, cut the steering wheel from side to side. if it hesitates or feels spongy, then the power steering pump/water pump belt needs to be tightened.
if the voltmeter drops, alternator light comes on, and/or the lights dim while you hear the screeching, it is either the compressor belt (crankshaft to compressor) or the alternator belt (compressor to alternator).
the crankshaft pulley is the large (main) pulley with 7 small lines scribed into the outer ring. the water pump pulley will have no holes, but 4 bolts, and the power steering pump has several large holes in it. I'm assuming you know what the alternator and compressor look like.
Now, to tighten them...... here is the easiest way.
(1) jack up the front end of your Maxima and remove the front passengers side wheel.
(2) with a philips-head screwdriver, unscrew and remove the splash shield behind the shock absorber. you will see the entire crankshaft pulley.
the inner belt about 1/2" thick runs from there around the water pump, around the power steering pump, and around a tensioner.
the thick outer belt about 1" thick runs from there to a tensioner, then to the compressor.
to tighten the water pump/power steering belt, locate the tensioner. it will be on the bottom under the car, near the crankshaft pulley. there will be a 12mm bolt on the bottom. turn this bolt to tighten/loosen the belt.
to tighten the compressor belt, the tensioner is on top, accessible from under the hood. it will be a little behind the compressor in a difficult spot to get to. the easiest way to describe it is to say follow the belt until it goes to the pulley where there is a 10mm bolt pointing upwards. this bolt tightens/loosens the belt, but you will need a long socket extension to reach this.
to tighten the alternator belt, get back underneath the car. loosen the 12mm bolt on the top of the alternator just a little bit, and do the same with the bottom bolt where there is a long screw. then turn the nut on the end of that long screw to loosen/tighten the belt.
that's basically all there is to it. while you're working with the belts, it's a good idea to check them out and see what their physical condition is. they should not be cracked, dry-rotted, deteriorated, peeling, damaged, etc. replacing them is really simple and any service manual covers this.
Old Jul 14, 2003 | 06:08 AM
max95q's Avatar
Ooh good faq to use thanks blackmaxima88. Can you say sticky!!
Old Jul 14, 2003 | 11:41 AM
huh?
Old Jul 15, 2003 | 07:22 AM
Rusty88se's Avatar
To tighten the belts it's best to know how much deflection there is supposed to be. Get a Factory Service Manual or a Haynes or Chilton manual which will tell you how much the belt is supposed to flex.
Old Jul 16, 2003 | 01:23 AM
owners manual would even have this info. or at least mine does.... I think. It has the deflections, but doesn't cover tightening them.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
