leaking power steering fluid... again...
Old Aug 10, 2003 | 04:23 PM
MoonKnight's Avatar
Yeah. I'm leaking power steering fluid again. I really should put a drip pan under my car so my driveway doesn't turn into one big spot. It can't be from the rack and pinion I don't think because I just had that replaced fairly recently. Anyone have any ideas where it could be leaking, and how I can stop it?
Old Aug 10, 2003 | 08:23 PM
pkfinn's Avatar
There aren't too many places it could be leaking from. You've got a hose from the reservoir to the pump and a hose from the pump to the rack and a return hose from the rack to the reservoir. Everything else is part of the rack. You need to clean it off and see if you can tell where it gets wet first. If you're lucky, it may be a loose hose clamp or banjo bolt seal.
If you just had the rack replaced, could you take it back to them and get it checked?
Old Aug 11, 2003 | 01:00 AM
MoonKnight's Avatar
Yeah I could do that. I'll have to talk to my dad about it tomorrow.
Old Aug 11, 2003 | 02:51 PM
maximase86's Avatar
I love lamp.
I would double check your connects. They are usually the first thing that leaks. Plus if they didn't tighten a banjo bolt correctly, it will leak like a ****.
S
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
2kmaximel
Sep 10, 2015 08:13 AM
ag90fox
Sep 9, 2015 12:22 PM
SusieQQ
Sep 9, 2015 12:14 PM
