cheap little improvements for the engine...
Old Aug 11, 2003 | 04:57 AM
Niku-Sama's Avatar
ok say i have waytoo much time on my hand because i have no job and such....is there any little engine tweaking i can do to improve things a bit...preferably low cost (like the regulator fix...where is that by the way?)
Old Aug 11, 2003 | 06:30 AM
86Wagon's Avatar
Re: cheap little improvements for the engine...
If you're talking about the air regulator fix...
Look about three posts up (give or take a post or two!).
Scott
Old Aug 11, 2003 | 10:15 AM
MaxWgn's Avatar
As for peformance, with no cost, the best thing would be to bump your timing up a little. If you're an auto (i can't remember if yours was), then you don't want to exceed 24 degrees, but you need to be able to run 93 octane or higher to maintain that time...best thing would be to take a timing gun, fill the tank with premium, and then bump the car up one degree at a time, until you hear it ping, then back it off one or two degrees. Do this while road testing it, as the car may not ping at idle, but could at speed, or while pulling a hill...
Old Aug 12, 2003 | 06:02 AM
pkfinn's Avatar
Here's a link to the air regulator fix. It won't really improve performance, just cold startability.
Air regulator repair
Old Aug 12, 2003 | 07:14 AM
Niku-Sama's Avatar
i have a problem with that any way
Pnjboyzz
Oct 7, 2015 10:47 PM
Sep 27, 2015 08:37 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
msellas
Sep 23, 2015 09:16 PM
