Low beams don't work
Old Sep 25, 2003 | 05:02 PM
image1's Avatar
Hey guys,
I have a 87 Max and my low beams don't work. The high beams work but not the low. I purchased new bulbs, same thing lows don't work highs do. Anybody have a clue what might be wrong?
Old Sep 25, 2003 | 05:09 PM
Jeff92se's Avatar
I'm needing a caw
1) fuse
2) relay
3) switch
4) dunno.
Old Sep 25, 2003 | 07:19 PM
MaxWgn's Avatar
Strong possiblity it's the switch...check and see if any other lights, other than the dome light, act odd...if it'sa the switch, save the hassle and buyt a new one, not one from a wrecking yard...they average about $125 for the entire combo switch the mounts to the column...
Old Sep 26, 2003 | 08:02 AM
image1's Avatar
Originally Posted by Jeff92se
1) fuse
2) relay
3) switch
4) dunno.
Where is the relay located?
Old Sep 26, 2003 | 04:11 PM
Niku-Sama's Avatar
does any thing buzz when you try to use your low beams?
Old Sep 26, 2003 | 05:46 PM
MaxWgn's Avatar
a bad relay will not always make a buzzing sound...the relay should be under the hood, next to the battery, in the relay control box, if i remember right...i could be wrong.
Old Sep 26, 2003 | 05:53 PM
Niku-Sama's Avatar
no not always but if it buzzes then its easier to find
Old Sep 26, 2003 | 07:49 PM
image1's Avatar
no buzzing. All the other lights work, turn signal and side marker lights. I will check the relay tomorrow and see if that is the problem. It's weird.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 10, 2015 11:21 AM
kenc15
Aug 5, 2015 08:29 AM
