buyin a 87, need your advice
Old Sep 26, 2003 | 09:51 PM
Supermax95's Avatar
hey guys, I was lookin at a car that i can use for the next few months till i get my other car up an running, and i came across a 87 maxima. I wanted to know what are the reliability issues with this car. What should i look out for, etc.
I came across an 87 with 180k miles on it. It looks decent, drives ok, and i talked the guy down to 500 bucks.....i need a car that wont break down on me causae im prety much broke as of the moment....what do u guys think??
thanks
Old Sep 27, 2003 | 12:06 AM
maximase86's Avatar
I love lamp.
Well for basic back and forth driving, it will work fine. The big things you need to look out for is the exhaust system, a timing belt will probably need to be done soon. Other than that, it should be good for basic transportation.
S
Old Sep 27, 2003 | 12:08 AM
Supermax95's Avatar
S
how can u check the timing belt on these.....also whats the normal compression supposed to be..imma run a compression check
Old Sep 27, 2003 | 12:29 AM
Niku-Sama's Avatar
i think...(because i'ver herd it so often) that the compression is 9:1...$500...thats awfully cheap....must be heavily used....oh and watch the voltage meter when you rev it...if it moves alot something alternator wize is screwy...or so i've been told....
Old Sep 27, 2003 | 02:18 AM
Supermax95's Avatar
I meant in psi....like 190 in each cylinder or something??
Old Sep 27, 2003 | 05:37 PM
Niku-Sama's Avatar
donno...can check my repair manual in a little bit though...had it out adjusting the timing and i thought i saw it
Old Sep 28, 2003 | 05:49 PM
maximase86's Avatar
I love lamp.
For the engine compression, hour engines should be a minimum of 128psi @ 300rpm, standard should be 173psi @300rpm. The diffrential limitation between cylinders is 14psi.
S
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
