C.V. Boot solutions
C.V. Boot solutions
I just noticed, that the right front outer C.V. boot is cracked all around at the root.
Since replacing the CV boot requires disassembling the front suspension partially, after that I should have to have a wheel alignment done as well (an extra $60)
So, I am playing with the thought of replacing the cracked CV boot with one that does not require removing the driveshaft from the hub.
I figured, that I might use "Camel" Rubber Cement to glue the boot together at the split to reinforce the connection in the split.
(and once its dry, I would pull it in the final position and clamp it.
Does someone know a relatively reliable split CV boot brand of such?
Geza
Geza
A split boot like that is only for a temporary band-aid fix...if you want to do it right, either have the CV joint rebuilt properly, or replace the entire axle. Axle replacement is not difficult, and I can tell you how to do it with requiring a front end alignment...
Hello MaxWgn,
Thanks for talking me out of using split boot.
I decided to replace the cracked boot with a regular (non-split) boot, today I called one of the 3 local dealers, he quoted me $52 for a CV boot kit that contains the boot, 2 clamps, grease and a circlip.
(I can get an aftermarket boot kit for about 10 bucks without the circlip, but I would feel safer to have a spare one in case it'd break since I will do the work on a side street Saturday morning.)
Do you know where could I get a circlip or a similar complete kit with the circlip? (for less). (I'd hate to pay 40 bucks for a circlip to be honest with you.)
I don't want to replace the whole driveshaft because it is in excellent shape (despite of 190,000 miles in it), because I could not be sure of the shape of a rebuilt one.
By checking my Maxima from a frog's perspective I also noticed that the swaybar bushings are shot and even the brackets lost their original symmetric shapes. Do you know of a place, where I could get some high performance bushing sets and maybe brackets from sturdier material?
I have to tell you that the road conditions in Los Angeles (San Fernando Valley) are not too good, lots of holes and cracks (Earthquake land, right?), that's why I have so much problems with the suspension.
Geza
Geza
Try www.partsamerica.com...when I looked up the boot kit, it showed everything except the grease, for $17.99 for the inner, and $15.99 for the outer. In comparison, the half-shafts are $87.99 ea there, for the Beck/Arnley units.
The half-shafts I got were CCT units from Autozone. Unfortunately, when I bought mine, they were $140 each, and now they're $60 each. Oh well, mine wouldn't have made it long enough for the price to come down.
Also, the bushings can be gotten at Autozone. I bought the universal end-link bushings, and universal polyeurethane bushings, including HD brackets, there. I had to take my old, worn out bushings in, though, to try and find the closest size to what was on the car...sorry, but I don't remember the part numbers.
I ended up buying a C.V. boot kit (Beck/Arnley) from Kragen Auto parts, it included everything (boot, 2 clamps, grease, and several circlips)
but I ended up ordering sway bar bushings and brackets from a small town Nissan dealer.
I realized, that all Nissan dealers in Los Angeles try to rip you off with prices where ever they can, but small town dealers are nicer folks, I guess because they meet you at the church every Sunday and want to be able to look into your eyes there.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
For example Miller Nissan in Van Nuys sells the sway bar bracket for $16.73/EACH!!! while the dealer in Thousand Oaks sells the same for only $9.08/ea.
Same price-difference ratio applies to all other parts, that I was inquring about.
Maxwgn, what is your experience with the poliurethan sway bar bushings? I checked them out at Autozone, but they seemed to feel so rigid, that I decided to pass on them, mainly because I am not a racing driver, I rather enjoy some music from the radio.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
At this store they only had bushing with brackets with greasing nipples, have you got yours with or without them?
Do they ever make squeaking noise?
Geza
Geza
It is a very good question. We'll see how Arnie will be able to pull the State of Calif. out of the ****, that it's in currently.
Does someone know what is the socket size for the front and rear hub nuts on our Maximas?
(I am going to do CV boot- and rear bearing jobs on it soon but I am not sure if I have the right size of socket(s).
Geza
Geza
I don't member correctly, but I think the fronts are like 26-28mm, and the rears are like 19-21mm...
As for the bushings, mine have the nips, which is no biggie to me...the end links don't squeek at all...the brackets a bush for the bar can and will if they are not greased...but the grease I shot them with when installing is still working it's magic...no squeeks at all...and the car is a LITTLE tighter when turning...don't lean as much...but the rear's are still rubber, until I find a way to stiffen them up...and maybe throw in a heavier bar...
I've also seen issues with pricing, as well...with my idling issue, I had to buy a fusible link...it was special order, and when they looked it up, they gave the suggested price of $13.98...when I picked it up, they charged their normal price, so my total was only $8.73....not much more than a parts house woulda charged...so not too shabby...
knight_yyz
11-01-2015 01:34 PM
jchronis2552
09-21-2015 05:52 AM
