Got a ?
Got a ?
Here lately my horn hasn't been working right sometimes it work and sometimes it don't but one thing I noticed is that when the horn don't work niether does the beeping from the key pad.Any one got any ideas here?
These cars are known for their crazy electrical problems. when I had mine, I noticed that when the air conditioner wouldn't kick on, neither would the 4-way flashers, and they're not part of the same circuit. and that's just the beginning. anyone here will tell you that these bad connections are a nightmare. my horn didn't work unless I really slammed on the wheel, and even then it was intermittent, and with the way people here in PA drive, a horn is as necessary as headlights and turn signals! but without getting too technical I'd pop off the center panel for the steering wheel where it says "NISSAN", and check the wire. if I'm not mistaken there's also a metal contact that touches the steering shaft when the panel is pushed.. completing the circuit and activating the horn relay.. make sure everything's clean and connected, and try again.
as for the beeping... I didn't have the pushbutton entry (88 SE), so I can't help you. sorry man.
