Resetting keyless entry code 1985 Maxi
I read an article about a year ago on how to reset the code by getting a code from my trunk, I was able to do it but I cannot remember how to do it again (battery was removed for about a month so i need to re do it)
If anyone can tell me which number and what I need to do with it I would appreciate it.
the keyless entry unit is in the trunk mounted on the ceiling between the speakers. on the bottom of it is a sticker with 3 rows of numbers the bottom one is a number marked "F# S#######" the 7 digits after the s(or whatever letter) is the number you use to set the keyless entry. go to the door press the code button and enter that 7 digit code. the keypad should now beep continuously for 10-15 seconds. *while* the keypad is making the beeps enter a 4-7 digit code of your choice. after the steady beeps end there should be a pause followed by 3 fast beeps signalling the unit accepted the code. after that just use the code you programed. if for some reason you decide to change the code again just re-enter that 7 digit code and do the process again.
-matt
-matt
magiconthetire
Oct 26, 2015 09:03 PM
