bolt on mods for HP
bolt on mods for HP
Hi, I have a Gen 2 maxima 1988, could someone post a list of boltons to increase horse power, nothing to $$, it's just a winter beater that I keep in great shape until the nice weather comes then the vette comes out. thanks for any responses.
Maxvette
Maxvette
Werd, welcome to the forums. What year Vette do you have?
Anyway, for bolt on mods, there isn't very much available, but you can do a few things:
Fabricated CAI: You can make your own CAI, just need mandrel bent pipe, a maf adapter, fitting, and a cone filter. You can build your own. One of the best things to get a little power out of your car.
Exhaust: Opening the exhaust on these car is great, but keep in mind, don't go too large or you loose some of the backpressure this car needs to make the torque it makes. 2.5" seems about the biggest you can go N/A. You can pull off 3" with boost.
Underdrive Pulley: This is a good way to free up power. Unorthodox makes one for our cars, but good luck trying to find one.
Lighten Flywheel: Fidenza makes one, you can use on for the 89-92 VG SOHC motor Maxima as well if you can't find one for the 85-88 specifically.
240SX/Stanza Thottle Body: Our stock TB's are 50mm, while the 89-92 Stanza/240SX TB are 60mm. You would have to port out your intake collector for this to work. Increases throttle response.
300ZX ECU: Another way to get optimal timing and A/F out of your motor. Be sure to use the ECU from the same year 300zx as your car, and make sure it's from the N/A motor and not the turbo.
Boost!: Best way to make power, T/C, S/C, or Nitrous. I can't go into detail now, but I can tell you what's involved.
S
S
S
S
Originally Posted by wylie-c
Hey S, did you ever get around to putting your UDP on your car yet?
Thanks for the response, the vette is a 1994 C4 just turning 49,500 miles color Black rose
S
litch
123
01-04-2024 07:01 PM
knight_yyz
11-01-2015 01:34 PM
RealityCheck
10-02-2015 06:34 PM
