forum is dead...someone build me an intake
Old May 19, 2004 | 06:38 AM
  #81
86Wagon's Avatar
Originally Posted by Jeff92se
Good news! I got two midpipes done! Both aren't perfect. So it's a toss up to which is better. And to my knowledge, the pipe sizes should fit. The little hose fitting that was too small on Sarin's was replaced by a brass barb style fitting on both of these.
I'll taper the pipe ends to make the hoses slip on easier. If anything, they are just a tad big
For the rest of the 3" pipe. It's all marked. Just has to be cut. One of the pipes will either be too long or okay. I'm not 100% sure on that dimension so best to leave it long vs short. It might work either way as it's the pipe that the filter is attached to(in the fender) This will only take 1/2 hour to cut.
As of right now, they aren't painted.
86wagon. If Spilk188 doesn't want the midpipe, I can probably grab another set of 3" pipe and duplicate the cuts for another complete setup.
Or I can just make another complete unit.
Now I would have liked to have Sarin's car to confirm all the little fitting sizes but again, I've done the best I could do considering I couldn't braze and use copper tubing. The steel fittings are close (very close in the OD measurements.)
So how much are ya asking? Any pics?
Scott
Old May 19, 2004 | 06:55 AM
  #82
cardana24's Avatar
Blown
sarin,
if you got a chance to take a close up picture of your mid pipe installed so I can see where all of the vacuum hoses come from and go to.....that wouls be great if you got a chance...it would also help so I will know what else I need to take out that I currently have installed with just the MAF adaptor and the cone filter....I am guessing the rest of the intake assembly comes out.
Old May 19, 2004 | 07:18 AM
  #83
Jeff92se's Avatar
I'm needing a caw
I'll try to work up a price. Do you guys need the couplings/hose clamps also?
I'm gonna buy some primer and silver paint and do these up tonight (with luck)
Sarin has pics in a zip file on the 2nd page.
Old May 19, 2004 | 07:23 AM
  #84
cardana24's Avatar
Blown
I would like couplings but I can buy clamps intown...I would perfer black couplings
Old May 19, 2004 | 07:56 AM
  #85
Jeff92se's Avatar
I'm needing a caw
I have black coupling material. I will just cut one section. Then you can cut to fit. You will need 4 sections. Some will be pretty thin width-wise so I hesitate to precut.
Old May 19, 2004 | 02:05 PM
  #86
86Wagon's Avatar
So the pics in the zip file are of your mid pipe, not little piggie's?
I'd take the coupling material (black as well) but I'll get the clamps locally.
Let me know the price!
Thanks!
Scott
Old May 19, 2004 | 02:14 PM
  #87
Jeff92se's Avatar
I'm needing a caw
The midpipe is maximarideous's work. The rest is Piggie's work. None of it is mine.
Old May 19, 2004 | 09:32 PM
  #88
Jeff92se's Avatar
I'm needing a caw
Pics are up!
http://community.webshots.com/album/144639551kVYvLw
Yes the welds are ooglie! heh. I took pics of the bare pipes and painted pipes. I sanded everything down and used some gloss black engine paint I had. It works well and is very tough paint. I used it to paint my bbk caliper relocating brackets.
Last pic shows the big 3" coupling tubing.
I'll try to pin down a price tomorrow.
Old May 20, 2004 | 04:40 AM
  #89
cardana24's Avatar
Blown
looks good to me!! , also jeff, where do you buy that coupling stuff? I need some for a future project.
Old May 20, 2004 | 06:30 AM
  #90
maximase86's Avatar
I love lamp.
I think that's like 3" radiator hose that you can get in bulk at most auto parts stores IIRC. Lookin good Jeff.
S
Old May 20, 2004 | 07:25 AM
  #91
Jeff92se's Avatar
I'm needing a caw
Yup. But you would be amazed how expensive it is. I got mine from Napa. Good quality. Seems alot more sturdy than just plain auto radiator hose. This stuff is for semis or something.
Old May 20, 2004 | 09:17 AM
  #92
maximumrideus's Avatar
Sarin
I graduate today so this weekend might be a go on the redesign. What was the correct size of your small fitting and do you got any other inputs for improvements?? Jeff, the very first picture of the complete CAI, I see the piece that goes through the fender that has the bend. How or where did you get that piece?You said earlier that you didnt know how to braze but if you have access to an oxy/acetylene torch I could explain it to you. its really not that bad...You could also use silver solder but its more of a pain in the ***. The brass flows better.
Old May 20, 2004 | 09:20 AM
  #93
Jeff92se's Avatar
I'm needing a caw
It's a brass barbed fitting. I'd have to look at the package. I don't even know if it's gonna work. Sarin just said the fitting needed to be bigger than the one you used(the smaller one). So I bought a size a bit bigger than that.
Just for the brass fitting, I used some stuff called liquid steel. It's used to fix leaky steel pipes etc... it can be painted, sanded, drilled, tap and died etc.. Should be plenty strong.
Old May 20, 2004 | 11:24 AM
  #94
Jeff92se's Avatar
I'm needing a caw
There seems to be some concern about this setup:
1) Materials. Most of it is 16ga aluminized mandrel bent steel. The exact same stuff most turbo charge pipes are made of. Exact same stuff 99% of all intake pipe is made of. It's plenty strong. What is the alternative? Aluminum? Will get just as hot and is harder to work with. Ever see mandrel bent aluminum pipe? PVC?? Will get soft when hot. And since this was NOT designed for automotive applications, there is no telling what chemicals are leached out when it gets hot(ie.. the plastic itself or the chemicals used to bond it together) It's also much thicker. Meaning you have to cut that much of a bigger hole in your fenderwell.
2) Like I said, the welds are ooglie . But it's strong and will work. That's what counts.
If you have concerns, comment it about it here. But at least I took the time to make one for a guy here. A guy not influenced by hearsay and false opinions. Just a guy that wanted one made. I commend that.
Old May 20, 2004 | 12:25 PM
  #95
maximase86's Avatar
I love lamp.
Another thing....I shouldn't have to do this, but I will. If you guys want, I can personally test the kit before it ships. If you get it and don't like it, you can go after me. I'll put my reputation on the line for this. I would hope that if you guys don't trust Jeff, that you at least trust me. I can guarantee this work and you shouldn't have anything to worry about as far as quality is concern.
S
Old May 20, 2004 | 12:32 PM
  #96
Jeff92se's Avatar
I'm needing a caw
It's a mandrel bent pipe. Usually used for free flowing exhaust sytems. Fully aluminized.
Originally Posted by maximumrideus
Sarin
Old May 20, 2004 | 02:13 PM
  #97
86Wagon's Avatar
S
Just waiting to hear a price... if I have a problem, I trust Jeff just fine to
make good... no worries here what-so-ever.
Scott
Old May 20, 2004 | 02:38 PM
  #98
Jeff92se's Avatar
I'm needing a caw
$110 shipped for everything in the pics. You will still need a filter (quality K&N is $35 ish from comoby) and a maf adaptor. $25 ish?
Old May 20, 2004 | 03:46 PM
  #99
Drjmaxx88's Avatar
Yo
You guys remeber what Sarin said about fighting on the internet?
Just because some people want to hate on you don't think we all feel that way! I think it's pretty dope that you would even have the testicular fortitude to try this.
You guys just think were we'd be if people only listened to they ney sayers!
I say hell yeah, keep it up your not going to be alone soon I'll trying to make stuff so lead the way brotha.
Besides too many people drink HATORADE!
Old May 21, 2004 | 05:08 AM
  #100
86Wagon's Avatar
Originally Posted by Drjmaxx88
Yo
Ummm... I must have missed something here...
Where was the fighting???
Seemed peaceful to me...
Scott
Old May 21, 2004 | 05:37 AM
  #101
Scott
Jeff
What I did for the piece going through the fender was, I bought a 90 degree exhaust elbow and just brased it to a straight piece of pipe. It came out good. After its in the fender, I used this PVC accordion type pipe from auto zone, that was meant for intakes. I ran that the rest of the way and put the cone filter on it. I'm thinkin of changing it to pipe though. I commend you to for doing what I've been doing. If you want to get the stuff done for your ride sometimes you have to take that iniative. After seeing what most of these intakes kits looked like, i figured I could do that. If you give me your email address I can send you pictures of my intake. Jose
Old May 21, 2004 | 09:32 AM
  #102
Jeff92se's Avatar
I'm needing a caw
I just saw an opportunity to make a CAI for one of the guys here. I had some of the parts already. It was fun. I hope it fits well.
Jeff
Old May 22, 2004 | 03:52 PM
  #103
Jeff92se's Avatar
I'm needing a caw
I shipped it today via usps priority. Expect it Monday or Tuesday.
Originally Posted by cardana24
thanks for the update....keep me posted on the progress
Old May 23, 2004 | 05:41 PM
  #104
cardana24's Avatar
Blown
Good deal ....what do you guys recomed to use to open up the hole going into the fenderwell? Saw-zaw? Drill with hole bit? Could use some suggestions. Thanks.
Carson
Old May 23, 2004 | 09:15 PM
  #105
maximase86's Avatar
I love lamp.
I use a dremel with cutting discs. I suggest that when you cut the hole, make it bigger than you need. It will allow you a little more flexibility when installing the piping, and allow the piping to move with the motor a little. Just becareful of the wiring harness that's there. Also there is ground there...which you'll see, be sure to relocate that.
S
Old May 23, 2004 | 09:27 PM
  #106
Jeff92se's Avatar
I'm needing a caw
I have a 4" grinder with a cut off wheel. Works well.
I just made my VE 3-gen cai today with some spare 3" tubing I had. But I just had to cut one little bracket off.
Old May 24, 2004 | 05:27 AM
  #107
86Wagon's Avatar
Carson
After cutting the hole, file down the rough edges and install some
door edge guard trim around the hole for that "finished" look.
Just a thought...
Scott
Old May 24, 2004 | 05:42 AM
  #108
cardana24's Avatar
Blown
where can you find that stuff?
Old May 24, 2004 | 07:25 AM
  #109
Jeff92se's Avatar
I'm needing a caw
Auto stores. Maybe some stuff that's designed as fender trim protectors.
Old May 24, 2004 | 10:40 AM
  #110
Jeff92se's Avatar
I'm needing a caw
Your CAI has been delivered Cardana24. That was fast. heh
Old May 24, 2004 | 10:48 AM
  #111
cardana24's Avatar
Blown
Good deal, I was about to ask your for a tracking number...hahahah. No time for that I am at work right now but I will swing by the house before I go to my second job to check it out. Thanks for everything so far. Do you know what K&N filter I will need to make this work....I have an injen filter on my fourth gen, I have a pancake, and I have the ebay one on my second gen right now....I will probably throw the ebay one in the trash, and just get a new K&N. Do you know the part number for the correct filter that will fit in the wheel well?
Old May 24, 2004 | 10:58 AM
  #112
Jeff92se's Avatar
I'm needing a caw
http://community.webshots.com/album/145789293SyrMnu
I just made my own custom CAI yesterday also.
This type might work. This one is a Cattman K&N CAI filter. See how it's more of a can vs cone? The cone styles are generally too wide.
Sarin used a 4gen Supercharger filters that comes with those kits. It's really thin. Ie barely wider than the 3" opening.
Old May 24, 2004 | 11:03 AM
  #113
cardana24's Avatar
Blown
The one that comes with the fourth gen S/C kit are actually the pancake style filter....Sarin has the one that some guys use for the custom CAI setups. I was thinking I wanted one like sarin just because I am sure it would fit...I will look around for one...if anyone knows the part number then please post away
Old May 24, 2004 | 11:25 AM
  #114
maximase86's Avatar
I love lamp.
Yeah, mine isn't the same one that comes with the s/c kits. I use one of the ones that most S/C guys use for thier CAI's. I'll try to get a shot of it, and see if there is a part number on it.
S
Old May 25, 2004 | 04:39 AM
  #115
cardana24's Avatar
Blown
everything looks good so far jeff....I will try to get this in by the end of this weekend....I still really need a part number or some sort of link for a filter...I really would not care but if I order the wrong filter that about a $50 mistake when going thru K&N
Old May 25, 2004 | 04:45 AM
  #116
cardana24's Avatar
Blown
will this size work?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old May 25, 2004 | 06:22 AM
  #117
maximase86's Avatar
I love lamp.
As long as it can fit a 3" pipe, that should work fine. That looks almost like what I have...very very close.
S
Old May 25, 2004 | 06:55 AM
  #118
cardana24's Avatar
Blown
yeah I think its close but I think I need a bigger opening...if I am reading this right then the I.D.(inside diameter) is not big enough....
S
Old May 25, 2004 | 08:14 AM
  #119
Jeff92se's Avatar
I'm needing a caw
2 1/8" opening is what I read. Too small I believe.
Old May 25, 2004 | 08:41 AM
  #120
cardana24's Avatar
Blown
does anyone know a part number of a filter that has a 3" opening and is a more narrow cone or possibly a 'can'...thanks.
Carson
