Maintanence at 80,000mi
Old Jul 31, 2004 | 07:48 AM
Y3k-Bug's Avatar
Just hit that mileage yesterday. Seeing as how I bought the car from the first owner at 78k a month ago, and also considering he was running the original set of brakes that came with the car (along with a front right rotor that was completely worn away, and 3 dead calipers) I think I should comb through the entire car and check for any other things this guy overlooked.
Things that were bad:
Sludged oil, original set of plugs that came with the car, original air filter that came with the car, 3 dead brake calipers, all brakes almost completely worn, rotted through right brake cable, exhaust leak in pipes, rotted muffler, driver's door doesn't open.
Things fixed:
oil change and flush, new NGK plugs (damn you to hell, Bosch.), new air filter, replaced 2 of the 3 seized calipers, new brakes all around, new rotor, new fuel filter
Gonna go and get a new O2 sensor from the dealer today, and try to install the PCV valve if I can ever find the damn thing in the intake manifold (could anyone point me in the direction of a picture of the valve while its installed in the car?).
Any specific systems I should be checking? Other than a the car being loud (which I've pinpointed at the exhaust leak), there seems to be no problems, but I rather be proactive than reactive when it comes to car troubles.
I've actually noticed that there are times when I maintain a given speed, the car will start to loss speed, and when I hit the accelerator, the engine doesn't get the power in that it should. This happens sporadically however. Could this be a tranny fluid problem? Came up pink on inspection, but the first owner never drove the car (maybe 2k miles a year in the past 10 years).
Thanks for any help you can provide.
Old Aug 2, 2004 | 06:06 AM
cardana24's Avatar
Blown
The PCV valve is on the firewall side of the intake manifold....it is pretty much right in the middle. It screws into the manifold, and has a hose hooked up to it.
As far as maintence: the timing belt should be changed ever 60K, and other than that, I have never had a car with that few miles...but most of mine have been in better shape than what you are describing. I would deff. change all of the fluids if the car has been sitting so much....then after that I would just fix things when they break. My .02
-Carson
devilz05
Mar 18, 2006 09:32 PM
SmokeSL
77
Jan 28, 2006 06:15 PM
2k2MaxiBlue
Nov 21, 2005 11:52 AM
irondoor17
Jun 29, 2004 03:34 PM
