Leaking exhaust manifold
Old Sep 10, 2004 | 09:59 PM
(_8*(l)Homer's Avatar
I've got a leaky exhaust manifold. When I accelerate is sounds like tat-tat-tat and increases with RPM. How do I fix this? I assume it is made of aluminum and has a crack where it's leaking, could I just weld a bead across the crack? Or do I need a new manifold?
Old Sep 10, 2004 | 10:04 PM
maximase86's Avatar
I love lamp.
You'd have to locate the leak, but you could probably weld it....however, VG's are notorious for breaking exhaust studs....so in all likelihood, your manifold is probably fine.
S
Old Sep 10, 2004 | 10:35 PM
Which stud may be broken? The sound is comming from the manifold area I believe. Are you refering to the bolts holding the pipe that connects the manifold to the flex pipe section?
Old Sep 10, 2004 | 10:45 PM
ASHURA's Avatar
exhaust manifold is cast iron...if it leaks, yes, you can weld it, but cast stuff are nasty to weld with..
Mar 12, 2020 12:06 AM
homeofbacon
Sep 23, 2015 07:17 PM
Hdnseek
Sep 9, 2015 05:55 AM
carid
Sep 9, 2015 05:06 AM
